Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Input on different wheel Size/Width/Offset Combos?
Old 05-01-2007, 07:53 PM
dt98gsr's Avatar
Default Input on different wheel Size/Width/Offset Combos?
Ok well I searched the "Wheel and Tire Upgrades Thread" and took a look at the "Wheel Fitment Recipe - wheel offsets that work" thread on 8thcivic and didn't see any of the sizes that the two wheels I am interested in are made in.
So I was hoping some of you guys could point me in the right direction or give me some input on the different option I am considering.
I don't really want to mention what wheels they are but the sizes are as follows:
<U>Option 1</U>
17" x 7.5" with an ET (or offset) of 48mm
with a
225/45/17 Tire most likely
<U>Option 2</U>
17" x 7.5" with an ET (or offset) of 45mm
with again a
<U>Option 3</U>
17" x 8" with an ET (or offset) of 40mm
with again a
225 or possibly 235/45/17 Tire most likely
Let me know which option you think may work the best, or if you think these sizes and offsets won't work well at all.
I've gotta believe atleast one of the 7.5" setups would work well without rubbing but I haven't seen anyone mention they are running wheels with those specs yet.
I am riding on stock suspension for now but eventually do plan on lowering the car and eliminating the tire gap.
*** UPDATE ****
I have come across a really great deal on one of the two wheels I was considering in 18 x 7.5 w/ a 45mm offset and after looking at pics of 18's vs. 17's I am strongly considering them.
OPTION 4
18" x 7.5" with an offset of 45mm
with most likely a 225/40/18 size tire
Modified by dt98gsr at 5:22 AM 5/3/2007
Old 05-01-2007, 07:58 PM
GRADSI's Avatar
Default Re: Input on different wheel Size/Width/Offset Combos? (dt98gsr)
I just got some 18x8 rims on 225 40's with the HFP suspension..looks and rides good as hell. Ride is a bit rougher but it feels tighter and handles better. Youll have to compromise somewhere. Check out some of the of the pics different members have of rims/ drop setups. Cool thing about this car is that its the **** stock.
Old 05-02-2007, 05:30 AM
dt98gsr's Avatar
Default Re: Input on different wheel Size/Width/Offset Combos? (GRADSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRADSI &raquo;</TD></TR><TR><TD CLASS="quote">I just got some 18x8 rims on 225 40's with the HFP suspension..looks and rides good as hell. Ride is a bit rougher but it feels tighter and handles better. Youll have to compromise somewhere. Check out some of the of the pics different members have of rims/ drop setups. Cool thing about this car is that its the **** stock. </TD></TR></TABLE>
Thanks for your input man. So what offset are you riding on with 18" x 8"?
Old 05-02-2007, 05:32 AM
Type X's Avatar
The problem you have is/will be your drop.
With most of the combos u posted up I was rolling with comptech springs with ZERO rubbing and it was noted as a 1.0/1.2 drop which was as close as you should be without being "too dropped"
Get feedback from people with the suspension you decide FIRST.... then focus on the rim fitments they have had.
Old 05-02-2007, 06:51 AM
dt98gsr's Avatar
Default Re: Input on different wheel Size/Width/Offset Combos? (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">The problem you have is/will be your drop.
Get feedback from people with the suspension you decide FIRST.... then focus on the rim fitments they have had.</TD></TR></TABLE>
Thanks for your input Mike. I figure you probably have more experience with different wheels setups on the Si than anyone so far.
You made a good point in deciding on suspension first and then wheels, its just tough finding people with different setups along the lines of what I am interested in. I was initially thinking of doing suspension first but then I kind of started to lean towards wheels because they wouldn't void my warranty. Or atleast if they did, I could more easily make a swap back to my stock wheels than swapping springs or coilovers out for stock struts if necessary.
So let me get this right, you think most of the wheel specs I have listed above would work fine with a more subtle spring drop like your Comptech setup, but with a more extreme drop I may run into rubbing issues?
Old 05-02-2007, 06:56 AM
dt98gsr's Avatar
I initially thought I wanted coilovers for my FG but given that it is Daily Driven I am now leaning towards the more practical drop/ride of springs or GC sleeved coilovers.
Given say a spring drop on something like TEIN S-techs, Eibach Sportlines, Comptech Springs (if I could even find them), or Ground Control sleeved coilovers (which are height adjustable).
Which 17" wheel spec do you guys think might work best?
I was considering 18's but like I said the car is daily driven and I don't think they are the most practical DD wheel.
Old 05-02-2007, 07:02 AM
exhaust_note's Avatar
you can look dope on 18's.
or just be ballin out on 17's..
if you got 17's. go atleast w/ a 225..
i got 235's and the meaty-ness looks bad ***.
Old 05-02-2007, 07:09 AM
dt98gsr's Avatar
Default Re: Input on different wheel Size/Width/Offset Combos? (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">you can look dope on 18's.
i got 235's and the meaty-ness looks bad ***.</TD></TR></TABLE>
Thanks for the advice man.
I know 18's would look hot, but I also know they wouldn't ride as well as 17's and the wheels and tires would cost more and weigh more, so thats whats kind of holding me back from 18's.
What size are your ce28's?
I was thinking I would go with a 225 for the 7.5" wheels the 215 was just what Tire Rack and other sites like them happened to recommend for some reason.
BTW, what kind of springs did you end up going with? Comptechs? If so how do you like them (are they daily drivable) and where did you find them?
Old 05-02-2007, 07:17 AM
im 17 x 7.5 +45 offset 235/45/17 Azenis w/ dem Comptech springs
215's are real thin. i didnt really notice it till i took the stocker off.
im running 215/45 azenis on the stocker for autoX and i think it was a mistake. i should have went w/ 225's
Old 05-02-2007, 07:21 AM
dt98gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">im 17 x 7.5 +45 offset 235/45/17 Azenis w/ dem Comptech springs
im running 215/45 azenis on the stocker for autoX and i think it was a mistake. i should have went w/ 225's</TD></TR></TABLE>
Cool, Yeah I think thats the wheel spec I am shooting for as of now, it seems to be a good mix of style and practicality.
If you don't mind me asking where did you find the Comptech Springs?
Old 05-02-2007, 12:17 PM
dt98gsr's Avatar
I have been told that the 17 x 7.5 with a 48mm offset would look like crap and rub.
Does anyone have any input on that?
I deleted the 18" wheels because I have pretty much decided I want to go with a 17" wheel, or atleast I think I have for now.
Old 05-02-2007, 12:34 PM
Type X's Avatar
17x7 oem wheels & oem tires w/ oem suspension = no rubbing
17x7 oem wheels & oem tires w/ Comptech springs = no rubbing
17x7.5 volk te37's 40mm w/oem tires w/ Comptech springs = no rubbing
17x7.5 volk te37's 40mm w/ goodyear f1 (oem size) w/ comptech springs = no rubbing
17x7.5 volk te37 ta's 48mm w/ goodyear f1's (oem size" w/ comptech springs = no rubbing
17x8 ssr professors 49mm w/ 225/45/17 Nitto Neo Gens w/ Comptech springs = no rubbing
18x7 element SC wheels 45mm w/ 225/40/18 Pilot Sport SP2's w/ Comptech springs = no rubbing
17x7 DC5 wheels 17x7 45mm w/ OEM tires w/ Comptech springs = no rubbing
18x7.5 Volk Te37's 40mm w/ MEGAN COILOVERS & Falken azenis 225/40/18
....slight rubbing on HIGH speed and heavy bumps depending on dampening and height settings which honestly.. is commonplace with a coil
Old 05-02-2007, 01:11 PM
barroomhero's Avatar
Im running 17x7 35mm offset up front dropped fairly low with no rubbing
17x8.5 in the back with 35mm offset and no rubbing either.
Old 05-02-2007, 04:34 PM
dt98gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">17x7 oem wheels & oem tires w/ oem suspension = no rubbing
Wow...Thanks a lot for that Mike, that helps out a lot!
I just had a couple other questions.
1. How did you like the look or fitment of the Time Attacks? I am considering a wheel withe a completely different loom but the same specs.
2. I didn't know you got coilovers. How do you like the Megans? I know what you mean about the occasional bottoming out or rubbing depending on height or dampening setting, I had coilovers on my daily driven GSR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barroomhero &raquo;</TD></TR><TR><TD CLASS="quote">Im running 17x7 35mm offset up front dropped fairly low with no rubbing
Hey thanks man for the input, I have always admired your FG, I love the old school wheels, I had no idea they were staggered though and 8.5's in the back, damn!
Do you by chance have any more pics of the car with the roof rack and/or the wheels? I actually work at a bike shop and ride all the time so I was considering picking up a rack, too bad Thule doesnt make one.
Old 05-02-2007, 05:34 PM
Here is a link to a few pics a buddy of mine took while i was working one day
http://www.azht.net/forum/showthread.php?t=29020
Old 05-02-2007, 05:39 PM
Default Re: (barroomhero)
My bad you prob have to be signed in
Old 05-02-2007, 05:56 PM
dt98gsr's Avatar
^^^ Thanks a lot for the pics man! I really like what you have done with your car.
What is it dropped on?
And btw what kind of riding do you do?
Since I don't think I am gonna go that low even if I go with coilovers since the car is daily driven, now I just have to decide if I want to go with 17's or 18's.
For some reason now that I am looking at more and more pics I am leaning towards 18's now.
Back to considering a 18 x 7.5 with a 45mm offset and a 225/40/18...hmmm...what to do?
Old 05-02-2007, 06:02 PM
anavrin351's Avatar
Default Re: (dt98gsr)
anyone have pics comparing a 225/40/18 to a 225/35/18. i did the calculator thing and the diamiter is almost half inch or so, but i was hoping someone had pics
Old 05-02-2007, 06:22 PM
icrashed's Avatar
I am running 17x7.5's with a 40 offset. Front tires are 235/45-17, rears are 225/45-17. Wheels are flush with fenders, have minor rubbing in the front but only in turns under a lot of load.... think high speed sweepers. Oh i am also dropped on S-Techs, and its a FA5.
Old 05-02-2007, 06:49 PM
Default Re: (icrashed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icrashed &raquo;</TD></TR><TR><TD CLASS="quote">I am running 17x7.5's with a 40 offset. Front tires are 235/45-17, rears are 225/45-17. Wheels are flush with fenders, have minor rubbing in the front but only in turns under a lot of load.... think high speed sweepers. Oh i am also dropped on S-Techs, and its a FA5.</TD></TR></TABLE>
you dont have ABS issuses??
Old 05-02-2007, 07:16 PM
L-Dawg's Avatar
Default Re:
17x7.5 +45 w/ 225/45/17 and HFP -- Will it rub (ever?)
17x7.5 +45 w/ 225/45/17 and HFP w/ Comptechs or Eibachs -- Will it rub (ever?)
17x7.5 +48 w/ 225/45/17 and HFP -- Will it rub (ever?)
17x7.5 +48 w/ 225/45/17 and HFP w/ Comptechs or Eibachs -- Will it rub (ever?)
+48 would look more flush with the fender, correct? Would I need spacers for these?
Thanks!
Old 05-02-2007, 07:24 PM
Default Re: Re: (L-Dawg)
the lower the number, the further the outside lip sticks out from the hub.
Old 05-02-2007, 08:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dt98gsr &raquo;</TD></TR><TR><TD CLASS="quote">^^^ Thanks a lot for the pics man! I really like what you have done with your car.
I ride urban/skatepark and dirtjumps on a single speed mtb.
as well as downhill.
and im lowerd on skunk2 springs
Old 05-02-2007, 08:08 PM
Tickle-shits
Tokyosmash!'s Avatar
Default Re: (exhaust_note)
you dont have ABS issuses??</TD></TR></TABLE>
ABS issues? care to explain?
Old 05-02-2007, 09:02 PM
bbRedSi's Avatar
just out of curiousity, why do you have 7's in the front and 8.5's in the rear?? on a fwd civic? j/w
Quick Reply: Input on different wheel Size/Width/Offset Combos?
