Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Headlights ajustment
Old 03-30-2013, 07:25 PM
April M.'s Avatar
Icon2 Headlights ajustment
Hi! I have 2013 civic lx and for the past 3 days the headlights are very dim to the point were you can barely tell they're on. Can anyone tell me how to make them brighter? The manual does not help. *does not have auto lights option. Thank you in advance :-)
Old 03-31-2013, 06:38 AM
97emsedan's Avatar
Default Re: Headlights ajustment
Check to see if the fuse is corroded or damaged. If the fuse is ok, check the battery connections are tight. If they are good, check the ground wire connection to the car chassis where the headlight wire harnesses go to each light. You might want to have your manual with you for harness tracing so you know which wires to look at and for the fuse number.
Old 04-03-2013, 05:33 PM
April M.'s Avatar
Thanks that helped
Old 04-04-2013, 11:53 AM
97emsedan's Avatar
No problems, glad to have helped...
kevinhughes13
11-03-2013 09:05 AM
be4unvme
22
07-02-2012 10:52 AM
Ciekiller
04-18-2008 02:32 PM
technine
11-09-2007 11:45 AM
USDMSiR
01-09-2007 05:28 PM
Quick Reply: Headlights ajustment
