Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Help dash problem
Old 12-05-2007, 08:23 AM
thunderboy's Avatar
Default Help dash problem
When you reset the oil life and it turns to 100%, does this reset your km/miles? Because i reseted the oil life and now don't see how many miles/km i've ride till now!
What should i do for seeing the miles/ km back?
Old 12-05-2007, 08:38 AM
Shiftyshadee's Avatar
Default Re: Help dash problem (thunderboy)
Please refer to this link for some help. I believe it should look familiar to you.
https://honda-tech.com/zerothread/2167709
Old 12-05-2007, 08:39 AM
civic1234's Avatar
are you talking about your A and B trip odometer or the actual car odometer?
Old 12-05-2007, 08:47 AM
Default Re: Help dash problem (civic1234)
Please refer to this link.
thunderboy's Avatar
actual car odometer
Old 12-05-2007, 08:50 AM
Press the select/reset button to get back to the odometer.
If you accidently reset your trip meter in the process of reseting the oil life than there is no way to recover that.
Once the trip meter is reset there is no going back.
<A HREF="https://honda-tech.com/zerothread/2167709
" TARGET="_blank">https://honda-tech.com/zerothread/2167709
</A>
Old 12-05-2007, 08:53 AM
thunderboy's Avatar
Default Re: Help dash problem (Shiftyshadee)
ok,thanks man, another question what is the honda civic 2006 radio code do know that because I don't know
Old 12-05-2007, 09:01 AM
That code should be on a plastic buisness card somewhere with the owners manual packet.
If its not, turn the cars ignition to run, turn off the radio, press and hold the #1 and #6 preset buttons while you turn the radio on. This will give you two series of numbers. This is the serial number for the radio.
Any Honda dealership will be able to give you the code if you provide them with the serial number.
You can PM the number to me if you like and I'll give you your code. I work at Victory Honda in Monroe MI.
92hybridAccord
08-08-2008 07:00 PM
Rahxephon
Honda Fit
07-06-2006 09:16 AM
boosted94teggy
03-24-2006 06:55 AM
.brian.
06-14-2005 01:37 PM
Buzzbomb
02-03-2004 01:20 PM
Quick Reply: Help dash problem
