Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Gauge cluster and fan problem
Old 03-01-2017, 01:40 PM
Josephsnodgrass's Avatar
Default Gauge cluster and fan problem
Have a 2008 honda civic. Car will start. In start up the gauge cluster goes through the check process then the temp gauge goes out. The check engine, abs, doors open, and TPMS lights are on. And the tach and speedometer are not working. Also the radiator fans do not come on. Tried two code readers and both say can not communicate.
any ideas?
Old 03-02-2017, 01:59 AM
holmesnmanny's Avatar
Default Re: Gauge cluster and fan problem
It might be wise to go see a local electrical specialist on this one.
Old 03-02-2017, 06:04 AM
Global Moderator
tech8's Avatar
The Gauge Control Module (instrument cluster module) is not probably not communicating with the PCM (power train control module).
Disconnect the negative battery cable for several minutes, to reset the modules and see if that makes a difference.
Old 03-02-2017, 01:57 PM
Disconnected battery overnight. No change. Where is the gauge cluster control module. I'm sure something is fried. Just not sure if it's the pcm since car will start. Don't think the gauge cluster itself is messed up cause it does the lamp check process just fine
boosted_ejcivic
Honda S2000
09-01-2015 12:57 PM
Dense
10
01-02-2008 07:46 PM
darkspector
04-10-2005 12:29 AM
5thgenallmotor
12-07-2004 07:48 AM
Rhetoric
09-14-2001 06:55 PM
Quick Reply: Gauge cluster and fan problem
