Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Airbag light on cluster
Old 11-15-2014, 11:48 AM
95ejjj's Avatar
Default Airbag light on cluster
car is an 08 si no accidents. the red airbag light on the cluster just popped up once it got below freezing, coincidence or not. some times it will stay off for about 10-15 minutes of driving then it will randomly pop up, and other times it will stay on right from the start. note this is not the passenger airbag light.
do I need to go to Honda to check the code? or can a parts store scanner do it? also will disconnecting the battery/reset the ecu work to see if itll come back on or not?
Old 11-15-2014, 11:56 AM
97emsedan's Avatar
Default Re: Airbag light on cluster
Do you store items under the drivers seat?
Check to see if the SRS harness is coming unplugged...
Old 11-15-2014, 12:00 PM
95ejjj's Avatar
no, I don't keep anything under either seat. but I will check both seat harness connections. thanks
Old 11-15-2014, 05:29 PM
97emsedan's Avatar
Hope it works.
The drivers SRS is more difficult to diagnose than the passenger bag.
Hope it isn't the module.
Old 11-16-2014, 08:57 AM
95ejjj's Avatar
I checked both harnesses under the seats And pushed in each connector a little. Cycled the key afterwards and the airbag light stayed off.
Did some searching and found there is a tsb for a loose/bad crimp on the srs harness for the front passenger side seat. Tsb # 10-001.
Old 11-16-2014, 09:16 AM
97emsedan's Avatar
Glad to help.
rawrjaay
Honda Civic (2001 - 2005)
08-26-2011 11:46 PM
eid_05
07-29-2011 12:28 AM
tyrone
06-06-2008 02:31 AM
tallblondkid
08-20-2005 04:13 AM
AccordCoupe
05-09-2003 10:00 AM
Quick Reply: Airbag light on cluster
