Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Why does my clutch make a tweeting noise (yes, like a bird)?
Old 06-30-2009, 03:17 PM
85_305's Avatar
Default Why does my clutch make a tweeting noise (yes, like a bird)?
When my clutch is pushed in, the car is pretty much dead silent. When I'm in the process of letting out the clutch, it makes a tweeting noise, and I used to think it was coincidentally birds chirping, while the clutch was being let out.
But I also notice that when the clutch is fully out, it makes a constant tweeting unless I rest my foot on the clutch and push it in maybe an inch or so.
What the hell is this? Is it normal?
Matt
Old 06-30-2009, 03:39 PM
Jstans84's Avatar
Default Re: Why does my clutch make a tweeting noise (yes, like a bird)?
The pedal might be loose or just need some lube. Mine used to squeak when I would press it in or let it out, I lubed it up and now its fine. Hopefully that is the only problem you have.
Old 06-30-2009, 03:42 PM
85_305's Avatar
Oooooh no no no.. I'm talking the ****ing motor tweets like a bird (or something under the hood anyhow). It literally sounds like my car has a Volkswagen style diverter valve. tweet, tweet.
When the car is fully in gear driving, it's constantly making this noise. And it's driving me batty.
Old 06-30-2009, 07:45 PM
Sanji
toyomatt84's Avatar
It's possible the throwout bearing is wearing out.
Old 07-01-2009, 01:05 PM
97el's Avatar
Doesn't the throwout bearing generally cause a noise when the clutch is disengaged?
Are you sure the clutch isn't slipping? I'm at a loss. I must say you have yourself a unique problem.
Old 07-01-2009, 01:57 PM
New User
lowlifestyle's Avatar
Could be the throwout bearing, it won't necessarily make a noise if there is no load on it(when your foot is on it) It could also be the beginning of the end for the clutch. How many miles on the clutch?
Old 07-02-2009, 04:32 AM
85_305's Avatar
I suppose thats possible. But it has a new clutch and hydraulic cylinders and all the other typical "new clutch" stuff.
Clutch is not slipping, I'm certain. I've tried putting it in a high gear and flooring it and there is no slippage. The clutch is actually pretty much new also.
The car has 40k miles on it, and the clutch is newer than that. I'd wager 5k miles tops.
Now to be honest, maybe my hearing is just in one of its moods (I'm almost deaf), but it seems as though since I've put the correct trans oil in (gm synchromesh) as opposed to the gear oil that was in it (and shouldn't have been..), the noise has stopped or it's super quiet now.
Old 07-02-2009, 11:33 AM
Sanji
toyomatt84's Avatar
Well, none of those parts include a throwout bearing. That bearing is almost unrelated to the parts mentioned.
Old 07-02-2009, 12:24 PM
85_305's Avatar
Isn't a throwout bearing a typical replacement part when you take your car to the dealer to get it changed out?
Old 07-02-2009, 12:33 PM
Sanji
toyomatt84's Avatar
Not that I know of.
Old 07-02-2009, 01:05 PM
RACEPAK's Avatar
everybody know about the bird. because the bird , bird , bird the bird is the word,
having the same problam
Old 07-02-2009, 03:45 PM
85_305's Avatar
^Are you really having the same problem?
I've noticed (and this was even before I did the trans swap so it's nothing I did) that often times after driving the car there is a rather pungent odor. The guy at the mechanics shop told me I didn't know how to drive stick cuz he smelled the burnt clutch, but I've been driving stick for about 8 years so I know how to drive. Something about this car smells strong, and even moreso under the hood. The clutch seems adjusted properly... it doesn't catch right away at the bottom, and it doesn't catch right away at the top... and it never sleeps even when under wot conditions.
Old 07-02-2009, 03:51 PM
CivicSD's Avatar
its not the throwout bearing, because if it was, it would make the noise with the clutch pushed in, and silent with the clutch let out.
all symtoms point to the input shaft bearing.
Old 07-02-2009, 03:55 PM
85_305's Avatar
Is this a bad condition? Because I think it's more faint now.. but not certain. I def. dont notice it that much anymore, and I'm very observant to my car.
Old 07-02-2009, 04:03 PM
rclark's Avatar
Well, the input shaft bearing is typically replaced with the clutch; its come in every clutch kit I've ever bought. Whenever I do a clutch I always do the throwout bearing too, but I don't know if a dealership would. Call up the dealership and ask exactly what they install with the clutch. My initial hunch was a bad clutch spring, but if the clutch is new that shouldn't be an issue. That leaves throwout bearing and input shaft. More than likely, it's one or the other... but my guess between those two would be input shaft bearing.
Old 07-02-2009, 04:06 PM
85_305's Avatar
The only thing that gets me is the car DRIVES EXCELLENT. In fact, if you were to go for a spin in my car, you probably wouldn't even be able to hear this noise.
Old 07-03-2009, 10:22 AM
85_305's Avatar
Well I had my buddy ride in it, and he said it's not the clutch.. 100%. He thinks the weird sweet-smelling burning smell might be trans fluid on the side of the trans thats burning off, which makes sense considering there WAS fluid on it. Or he said the fluid inside the trans might be burning (that sounds odd?)
But I think the tweeting might be gone. Pretty sure the new gm synchromesh fixed and and removing the gear oil that shouldn't have been in there.
Old 07-03-2009, 11:03 AM
Sanji
toyomatt84's Avatar
Coolant also has a sweet smell when it burns. Almost like maple syrup.
Old 07-03-2009, 11:14 AM
rEM2's Avatar
Isnt this due to the clutch master cylinder having no lube/grease left on it making this noise. Many people from other sites who have 7thgens have this problem and they lube it up but it does come back, my car is 'chirping' also and its more annoying than anything else. The only real way to get rid of the squeak is to install a k series motor because they do not have shitty problems like the d17 lol
Old 07-03-2009, 12:18 PM
85_305's Avatar
Hmm. Now that is an interesting thought. There isn't a cooling issue, and there isn't any fluid gone though. Thats strange?
Are you talking about the actual piece that pushes on the clutch squeeking? When I put the new trans in, that rubber boot piece wasn't put back in. Maybe that would silence the squeaking?
Old 07-03-2009, 08:57 PM
Sanji
toyomatt84's Avatar
If you changed coolant recently, residue could be still on the block/header/etc....
Old 07-03-2009, 11:20 PM
slammed em1's Avatar
happened to my boi wen he bought the car.....we found out thought the tranny was being bolted by 3 screws from home depot!!
Old 07-04-2009, 05:41 AM
85_305's Avatar
This smell has been occuring for a few months now, since when I had the old busted transmission in, so I cant fathom there is still coolant somewhere?
Old 07-04-2009, 07:55 AM
Sanji
toyomatt84's Avatar
You might not want to insult your friend by calling him that.
http://lesbianlife.about.com/od/trans/g/Boi.htm
Old 07-04-2009, 09:19 AM
85_305's Avatar
AAAAaaaaaaaaaaahahahahaha thats awesome
Quick Reply: Why does my clutch make a tweeting noise (yes, like a bird)?
