tranny mariage
Re: tranny mariage
Ok , toy or projay, , step in and help me out. I replaced lots a manual tranny on the 93 thru 00 models, mostly the D15B engines. Most all the manual trannys were direct bolt in replacements..no matter V tec or Non V tec., as Sickcpe is asking, . BUT, they made several different models trannys, A s and B s were how they were stamped. This was done when they changed to different internal gear ratio s . As you know Civics in the past models came with 13, 14, 15 inch tires, hence different ratios needed. So, toy, what are all the tire sizes available on the 01 to 05 models.....and was the manual trannys different to accommodate the different ratios . I assume most were 15 inch, were any 16 or 17 inch tires ever offered......
