Swaping
Sanji
Re: Swaping
The middle octet will be the most crucial in identifying what ECU is needed.
Example: 37820-P72-A01
The "P72" portion refers to the chassis; in this case "P72" refers to a 96-00 OBD-2 Integra GSR.
For more detailed information: https://www.hondata.com/tech-ecu-identification
Re: Swaping
Many ECU types will NOT match the engine code or block/cylinder head markings, so I suggest you use an online parts catalog to look up what year and model the engine is from, then choose the "control unit - cabin" selection and check the part number of the ECU. Then you know.
If this is confusing, tell US what engine you are trying to match an ECU to and we can help.
