Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Squeaking noise...
Old 01-26-2010, 05:08 PM
GAngulo7's Avatar
Icon2 Squeaking noise...
Hey guys, so I've noticed this weird squeaking noise coming from my car. The noise only sounds while LETTING GO of the brakes... While braking it makes no noise at all, but while I take my foot off the brake it makes a strange squeak. At first I thought it was the brake pads but figured that probably isn't it since it doesn't actually make a noise while I'm braking. Any ideas what this might be?
Old 01-26-2010, 06:21 PM
DynastyRacer22's Avatar
Default Re: Squeaking noise...
mines doing the same thing it happened after an alignment i believe its from the rear brakes theres a topic about it on here somewhere i just havent had the chance to check it out
Old 01-26-2010, 08:17 PM
Plead da Fif
It Wasn't Me's Avatar
There are a few spots on the rear brake assembly that need to be lubed.
If they're not lubed, or if it has worn off, the brakes will let out an audible chirp/squeak when you remove your foot from the brake pedal.
Mine used to do the same thing.
StockEm2
Suspension & Brakes
06-18-2009 11:10 PM
wsuozzie
08-18-2006 10:17 AM
Quick Reply: Squeaking noise...
