Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Spark plugs question
Old 07-12-2009, 10:05 PM
aznomb's Avatar
Default Spark plugs question
How often do u need to change the spark plugs? How do u check them to c if they need replacement? I have 03 civic coupe
Old 07-12-2009, 10:17 PM
Plead da Fif
It Wasn't Me's Avatar
Default Re: Spark plugs question
FAQ's
Edit: Replace them if they look worn, cracked, burnt, or fouled (oil, carbon, etc)
Old 07-12-2009, 10:40 PM
Sanji
toyomatt84's Avatar
Originally Posted by It Wasn't Me
More specifically: https://honda-tech.com/zerothread/2389234
Old 07-12-2009, 10:47 PM
Plead da Fif
aw come on.. it's not hard to find in there.
Old 07-12-2009, 11:03 PM
aznomb's Avatar
so replace it at 110K? im at 76K, so does it mean i have a long way to go?
Old 07-12-2009, 11:06 PM
Plead da Fif
Pull them out and check them. Just because the recommendation is 110k, doesn't mean your plugs don't already need to be replaced.
Old 07-13-2009, 12:02 AM
aznomb's Avatar
like i said, how do i check them?
Old 07-13-2009, 12:19 AM
Sanji
toyomatt84's Avatar
Are you asking how to remove them, or how to inspect them?
Old 07-13-2009, 03:29 AM
aznomb's Avatar
both
Old 07-13-2009, 04:33 AM
Plead da Fif
Originally Posted by Owner's Manual Pages 227 - 229
1. Remove the (black plastic) cover by turning the two clips one quarter turn counterclockwise.
2.
Clean up any dirt and oil that have collected around the ignition coils.
3.
Use a wrench to remove the nut holding the ignition coil. Remove the ignition coil by pulling it straight out.
4.
Disconnect the wire connector from the ignition coil by pushing on the lock tab and pulling on the connector. Pull on the plastic connector, not the wires.
5.
Remove the spark plug with a 5/8" (16mm) spark plug socket.
6.
Put the new spark plug into the socket; then screw it into the hole. Screw it in by hand so you do not crossthread it.
7.
Torque the spark plug. (If you do not have a torque wrench, tighten the spark plug two-thirds of a turn after it contacts the cylinder head.) Tightening torque: 13lbf-ft (18 N-m , 1.8 kgf-m)
8.
Install the ignition coil. Reinstall the nut.
9.
Push the wire connector onto the ignition coil. Make sure it locks in place.
10.
Repeat this procedure for the other three spark plugs.
11.
Reinstall the cover.
Specifications:
NGK: PZFR6F-11
Denso: PKJ20CR-M11
Spark Plug Gap:
0.04" (1.1mm) +0 -0.1mm
As far as inspection goes; if they're cracked, black, grey/white, ashy, goobered with carbon, etc etc. - replace them. If you're unsure, take a picture of your spark plug after you remove it, and post it on here. Someone will tell if they need to be replaced.
Old 07-13-2009, 09:32 AM
Sanji
toyomatt84's Avatar
both
How to remove spark plugs
How to inspect spark plugs
KandabashiDevil
12-10-2011 10:12 AM
adam00
01-30-2009 12:47 PM
Nocturnal
03-28-2003 05:25 PM
Aerodeck
02-16-2003 07:28 AM
nsx-Animal
07-30-2002 04:22 AM
Quick Reply: Spark plugs question
