Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
automatic vs. manual throttle bodys? high idle after new motor
Old 11-17-2010, 08:58 PM
Maple50175's Avatar
Default automatic vs. manual throttle bodys? high idle after new motor
Ok I got an 02 civic. Swapped an ex motor. Had an lx motor. The new motor is from an auto. I got it installed yet the idle is high 1500rpms. Why is that? Are the auto throttle body diff? It looks the same.
I have no vac leaks and everything is where it should be.. this is the only thing I'm guessing it is.
Old 11-17-2010, 09:19 PM
tjg312's Avatar
Default Re: automatic vs. manual throttle bodys? high idle after new motor
could be that the ECU just has finished adjusting? other than that not too sure
Old 11-18-2010, 05:54 AM
Sanji
toyomatt84's Avatar
Check the Idle Air Control Valve. I cannot recall if there's an idle adjustment screw on the D17 throttle body, as it's been over 4 years since I've had one.
Old 11-18-2010, 08:55 AM
theineffable's Avatar
i think idle speed is controlled by the ECU and based on coolant temperature?
so the car starts up at 1500 rpm but idle won't drop down to around 700rpm?
Old 11-18-2010, 05:06 PM
Maple50175's Avatar
Hey there, I got KPRO can i get a picture of the idle air control valve? i want to see if the wires are messed
thewrai6th
10-28-2018 05:32 PM
smurf357
12-02-2012 11:33 AM
90AcuraIntegra04
11-21-2005 02:33 PM
accordtuner96
09-14-2004 05:42 AM
japspecjohn
14
02-04-2004 08:20 AM
Quick Reply: automatic vs. manual throttle bodys? high idle after new motor
