Gauge Cluster Wire Color Codes
Hi Guys
I am looking for a diagram that show what color wires are used for for a 2002 civic ex auto for a gauge cluster. something like this:
http://img.photobucket.com/albums/v4...-00diagram.gif
Ive been searching all night an cannot find anything.
if this helps i need to know the wire colors for:
ground- black
trunk light or hatch-???
right turn signal-green/yellow
left trun signal-green red
brake light-???
seatbelt light-red/blue??????
low fuel-blue/orange
fuel gauge-yellow black
speedo-blue/white
tach-blue
temp-??????
power-yellow(green harness)
charging light-???
oil pressure-yellow/red
power-red/black (blue harness)
check engine-green/orange
high beam-red/blue (red blue is already in use for seatbelt)????
dimmer-?????
gauge lights
power- white/red (green harness)
I am doing this cluster swap into an ek. the rpms work, the speedo seems sluggish like its not reading properly, the water temp doesnt work. the fuel works but my empty sits at 1/2 tank on the cluster. the high beam, trunk, dimmer dont work. and the brake light will not go off. any ideas??????
thanks
ground- black
brake light-???
speedo-blue/white
tach-blue
temp-??????
charging light-???
dimmer-?????
gauge lights
thanks
Re: Gauge Cluster Wire Color Codes
what color is the temp wire? example: blue/green
i have the rpms and speedo working. the fuel works but the 1/2 mark is where my gauge reads zero
the only thing i really need working right now is the temp gauge
ok cool man here is a link to the ek cluster. i need to match up pretty much all of them to the es2 cluster.
i really dont care about the srs abs or cruise. i dont have that in my car im just worried about the ust haves in the cluster.
thanks again! this is a huge help.
ya i thought it was the white green wire but i hooked it up and nothing happened.
should i try tapping it to the ecu? i have a p30 ecu
hey guys
heres a little update. everything works on the cluster except the damn water temp. the fuels 1/2 mark is my empty lol but i can deal with that.
the ebrake light stays on but thats nothing big either.
can anyway shed some light on the water temp???? i have the correct wire- white green to yellow green. nothing is working.
all the gauges do tiny jumps for about 5 sec when i first turn the car on so i know the water temp is working but not reading.... any thoughts?
afterdark
10
02-25-2012 09:31 AM
vtecn8ive
27
11-04-2007 05:41 AM
