Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
engine and trans removal and install
Old 08-27-2011, 08:41 AM
  #26
AccordEX1991's Avatar
Default Re: engine and trans removal and install
Is the engine back in the car? That sucks, now you have to replace the water pump with a very tight space with engine in car already.
My engine/tranny is back in the car. New tranny, clutch, engine mounts, timing belt and roller and original water pump. 180k miles and good for another 100 miles. yippeee !
Old 02-01-2012, 08:09 PM
  #27
norcali707's Avatar
hey. do you have pics of the axles? did you took it off or what? I am about to take the engine and tranny to replace my tranny.
Old 02-02-2012, 02:41 AM
  #28
No. i did not take pictures of the axles. Yes, I took the axles out because I pulled both tranny and engine in one piece.
I removed the axle nut and removed the spindle knuckle from the strut and the tie rod to pull the axle out.
Old 01-16-2014, 03:01 PM
  #29
potatoe's Avatar
how do you disconnect wire harness and keep it with engine and trans when removing? do you need to get behind the firewall, or can you pull harness out and unplug? thanks
i know its an old post but i was searching the internet and this post popped up. im a member at another honda site and just signed up[ to this one. thanks
Old 01-16-2014, 04:58 PM
  #30
grjr's Avatar
you unplug the harness from the ecu under the glove box and just push the rubber grommet and harness out towards the engine bay
Old 01-17-2014, 08:38 AM
  #31
potatoe's Avatar
ive tried to access under there by removing glove box and bottom panel, but still having trouble getting to it or locating it. does more parts in the dash need to be removed? i have 2001 civic ex, 5 speed. thanks
Old 01-17-2014, 08:40 AM
  #32
potatoe's Avatar
nevermind, i found it. thanks for the info.
type Gendy
17
01-04-2008 08:14 AM
joe's_yj
06-21-2007 07:18 AM
wfocrx
03-08-2007 06:29 PM
lude98SH
07-02-2006 04:51 PM
floriudabrain
01-13-2006 10:56 PM
Quick Reply: engine and trans removal and install
