Dimensions of Trunk
Re: Dimensions of Trunk
I'm thinking an '05 has the same trunk dimensions. Can you be more specific? No, you can't slide a 4' x 8' sheet of plywood in there.
What I want to do is cut out and wrap a piece of plywood to go across and spice up my enclosure. If any other ideas for trunk enclosures throw them my way
Step 1. Buy a tape measure
Step 2. Go outside and measure your trunk
Edit: Make a template out of cardboard. Just trim it in small increments so you don't have to start over. This way you can just trace the pattern on to the MDF. (assuming you'll be using MDF)
96 SOHC VTEC
01-08-2003 02:01 PM
