Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic EX 2001 Keyless entry unit issue
Old 10-24-2015, 01:13 PM
nodir's Avatar
Icon5 Civic EX 2001 Keyless entry unit issue
Hi people,
1. Could you help locate the keyless entry unit in Civic EX 2001 Coupe model? I have 2 remotes, when I click LOCK lights go on 1 time and off, I can hear relay sound under the dash. When I click second time, I can hear door actuators low click voice on both doors but doors do not lock. I don't get any horn signal feedback after clicking LOCK also, I don't get any LOUD horn signal after second click on LOCK.
2. Inside the car, when I sit and click power lock button on the door, it does not lock (button with red mark does not go down). I checked both GROUND and POWER supply (12 v) to the door lock switch (voltmeter showed 12 v when I click lock on switch and negative -12 v when I click down switch). I am really puzzled how to make the car LOCK both doors and give a HORN signal.
P.S: Panic button does not work also.
Best,
N
Old 10-24-2015, 01:49 PM
nodir's Avatar
Default Re: Civic EX 2001 Keyless entry unit issue
Correction: PANIC button works nice. Just had to click for longer time. The rest is still not worked as mentioned above.
P.S: I completely freak out when horn gave loud signal after PANIC button click. Did not expected
Old 10-25-2015, 12:39 AM
Sanji
toyomatt84's Avatar
The factory keyless entry module is mounted under the head unit, behind where the cigarette lighter is mounted.
Old 10-25-2015, 05:22 PM
Former User's Avatar
You may have more than one problem, but it seems likely that the two door lock actuators are bad based on your voltage test result.
Alternatively, it's a mechanical problem with the locks. Is it easy to manually lock and unlock?
Old 10-25-2015, 06:00 PM
nodir's Avatar
Manual lock/unlock is easy for both doors separately. Do you think booth door actuators are bad even they give "click" sound on second click on LOCK button of remote?
Old 10-25-2015, 06:04 PM
If you don't trust your voltage tests, then run power and ground wires directly from battery to actuator. Does it lock and unlock now? If not, replace the actuator.
Old 04-12-2017, 02:18 PM
Jonathan Araujo's Avatar
Hi, I'm with a similar problem. After I configured the keyless entry just the drivers door closes using it and the manual lock switch.
Before I programmed the fob, the lock switch would lock both doors, so the passengers door actuator is not the problem (I guess).
What could it be?
Thanks in advance!
Old 04-12-2017, 07:46 PM
bbarbulo's Avatar
door lock modules are quite a common failure, I had my pass side one go out. I didn't notice it for like 2 years cuz i never use the pass side door. once i knew it was bad, i replaced the module. they're super cheap on ebay and so far so good. works nice and quiet - not bad for like $7 bucks shipped lol
ReneB64
Honda Civic (2006 - 2015)
10-06-2017 08:19 AM
cj7clay
02-20-2013 04:18 PM
SXT15
10-16-2008 02:05 PM
musicpyro2000
02-08-2008 05:39 PM
Quick Reply: Civic EX 2001 Keyless entry unit issue
