Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Need advice with my coilover problem
Old 04-26-2011, 07:07 PM
adrian1200's Avatar
Default Need advice with my coilover problem
Hey guys, Ive been on the site lurking and I'm in need for some help. Bought a set of used coilovers from a buddy of mine. One of the rears is missing a bushing so cant bolt up to my LCA. Bought them for cheap and I knew when i did buy them, I get what i paid for. I'll post pics to make it easier for you guys to diagnose. I appreciate it, thanks everyone.
Heres the problem:
Couple of pics to see which F2 they are. They look old school.
Old 04-26-2011, 07:42 PM
01_civic's Avatar
Default Re: Need advice with my coilover problem
well your problem is quite obvious....either source out a bushing or call F&F to see if they supply the part separately.
Old 04-26-2011, 07:49 PM
Sanji
toyomatt84's Avatar
From the look of them, they appear to be the first generation Function & Form coilovers. I hate to be the bearer of bad news, but even if you did replace the bushing, the dampers are most likely blown. It only took 7 months for all 4 of mine to blow out, back when I bought them brand new. My passenger front strut was so bad, that it made the suspension react as if it had a blown ball joint (over an inch of play on the wheel, due to the blown strut having so much shaft play).
Old 04-26-2011, 08:01 PM
eg_star's Avatar
I'd say replace the bushing as well, but like toyotatt84 said, the dampers would most likely be blown. Do you know how long your buddy had them installed?
Also I would maybe suggest that if your looking for a cheaper set up initially (later on upgrade to full coliovers), start with coilover sleeves with adjustable shocks. A buddy of mine picked up a used set for 3 bills.
maani89
04-04-2014 01:53 AM
iNfAmOuS_E46
Suspension & Brakes
12
03-02-2012 03:42 PM
adrian1200
Suspension & Brakes
04-29-2011 01:38 PM
fms1day
Suspension & Brakes
06-24-2005 07:20 AM
fms1day
06-23-2005 02:50 PM
Quick Reply: Need advice with my coilover problem
