Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
AC condenser fan fuse keeps blowing
Old 06-17-2014, 11:07 AM
nonno's Avatar
Default AC condenser fan fuse keeps blowing
The fuse for the AC condenser fan on my 2002 civic keeps blowing. Any ideas?
Old 06-17-2014, 01:16 PM
Global Moderator
tech8's Avatar
Default Re: AC condenser fan fuse keeps blowing
It may be the AC condenser fan motor or the wiring shorted.
Unplug the connector to the AC condenser fan. If the fuse doesn't blow anymore, it probably is the motor. On the motor side connector, you can check for continuity between the motor's Blu/Blk wire and body ground. Blu/Blk wire is a blue wire with a blk stripe running through it. If there is continuity to ground on the Blu/Blk wire, you probably have a short in the motor.
Old 06-17-2014, 06:06 PM
nonno's Avatar
Thanks.
DaX
21
05-23-2019 09:27 AM
Xjbw1983
08-30-2016 01:49 PM
ek9_B18C
10-06-2012 02:59 PM
orangeracer
06-28-2008 09:01 AM
FLCivic
12-18-2007 04:37 PM
Quick Reply: AC condenser fan fuse keeps blowing
