2005 Honda Civic runs rough when accelerating
My Honda only runs rough when it's warm outside, like over 70 F and only when I first start it accelerate it in gear. Recently it threw a couple misfire codes and I changed the spark plugs which helped but I feel like they fouled quicker than they should have since I changed them about 1 year prior. I've also changed the fuel filter/ pump and an oxygen sensor. I was just wondering what could cause this weird problem. Thanks.
Re: 2005 Honda Civic runs rough when accelerating
incorrect engine coolant temp or intake air temp reading will do this too. check the readings with and OBDII scanner
I just got a code yesterday and it was a cylinder 1 misfire. I pulled out the ignition coil to switch it with cylinder 4 to see if the ignition coil was the problem and there was a little bit of oil on the outside of the coil. I'll check out the EGR valve when I get a chance.
Noel Yeow
Honda Civic (2001 - 2005)
07-26-2012 10:16 PM
sethmoman
12
12-28-2011 10:00 PM
hondaowner
04-06-2004 04:42 AM
