Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic AC Questions
Old 09-28-2015, 04:06 PM
Z20rider's Avatar
Default 2001 Civic AC Questions
Clutch/pulley wobbling and making load racket. Replaced compressor, dryer, and expansion valve. Flushed system. New compressor had two oz. oil in it. Put 2 oz. back in comp. added 2 more to comp and 3 oz. in dryer. Replaced all o rings. Pulled vacuum for 30 minutes. Charged with 12 oz 134. Compressor will not come on. Ran 12 volt straight to comp to get it on. Low side pressure 20 psig high side 300 psig. Why would pressure be so high and what else could prevent comp. from coming on?
Old 09-28-2015, 05:49 PM
Former User's Avatar
Default Re: 2001 Civic AC Questions
Check for blown fuses in the A/C compressor clutch circuit. Do the fans run?
Old 09-29-2015, 04:55 AM
Z20rider's Avatar
No, fan does not run. 20 amp fuse good under hood. Swapped relay still nothing.
Old 09-29-2015, 05:44 AM
You need to test two separate fuses:
20A hood fuse 1
10A dash fuse 14
Use this method:
https://honda-tech.com/honda-civic-d...fuses-3079359/
Old 09-29-2015, 06:06 AM
Z20rider's Avatar
Tested per instructions. Both good.
Old 09-29-2015, 06:59 AM
A Blu/Wht wire runs from the multiplex control unit to the A/C pressure switch. If you unplug this switch and ground the Blu/Wht wire in the free connector, does the A/C clutch engage and the condenser fan run with the key in ON(II)?
Old 09-29-2015, 08:43 AM
Z20rider's Avatar
Grounded blue whit wire. Nothing. I jumper end the low pressure switch and still nothing. Only way I've gotten the comp to come on is 12 volt straight to comp connector.
Old 09-29-2015, 09:03 AM
A Yel wire that activates the fan and clutch runs from the ECU to the multiplex control unit. In the connector that plugs into the multiplex control unit, ground the Yel wire with the key in ON(II). Do the fans run and the clutch engage?
Old 09-29-2015, 09:04 AM
Z20rider's Avatar
Cooling fans are coming on and off but comp has to be ran off 12 volt wire to connector
Old 09-29-2015, 09:07 AM
With Yel wire in multiplex control unit connector grounded?
Old 09-29-2015, 09:25 AM
Z20rider's Avatar
Multiplex is the control switch on the console?
Old 09-29-2015, 09:36 AM
Diagrams for the 02-03 Si:
Old 09-29-2015, 09:41 AM
Si A/C system circuit diagram:
Old 09-29-2015, 03:41 PM
Z20rider's Avatar
Thanks for the help. I won't be able to work on it for a few days. I'll check multiplex as soon as I can.
Old 10-03-2015, 07:08 AM
Z20rider's Avatar
Not sure where the yellow wire is. Back (engine side) or front of multiplex ?
Old 10-03-2015, 05:42 PM
Connector E is located at the front of the dash fuse box.
Old 10-06-2015, 05:25 AM
Z20rider's Avatar
Thanks. Had something come up. Won't be able to look at it until later in the week.
Finally able to work on this problem some more. Do you ground the yellow wire with the connector plugged in or unplugged? I tested it with the connector plugged in and still nothing.
Old 10-23-2015, 07:54 PM
Either way.
With key in ON(II)? Fans don't run and compressor clutch does not engage?
Old 10-24-2015, 05:46 AM
Z20rider's Avatar
Correct. Nothing.
Old 10-24-2015, 07:05 AM
Unplug ECU connectors B and E.
Turn key to ON(II).
1) Ground the green wire at ECU connector pin B6. Do the fans run?
2) Ground the red wire at ECU connector pin E18. Does compressor clutch engage (click sound)?
Old 10-24-2015, 08:37 AM
Z20rider's Avatar
Yes and yes
Old 10-24-2015, 08:44 AM
Use a multimeter to test whether the Yel wire that runs between ECU pin E24 and MCU pin E10 is broken (no continuity between endpoints).
Old 10-24-2015, 08:55 AM
Z20rider's Avatar
Green wire grounded fans run.
Red wire grounded clutch engages.
Old 10-24-2015, 09:19 AM
Old 10-24-2015, 09:24 AM
Z20rider's Avatar
Yellow wire shows to be good.
Quick Reply: 2001 Civic AC Questions
