best way to remove window tint
Re: best way to remove window tint (streetracerof06)
I just did mine--- go to Wal-Mart and get Ammonia. By the cleaning products. Just mix it with some water and spray it on. Let it sit a few mins and then use a razor blade to get it going and to remove the excess residue. Pretty easy actually. Just try to pull it off in one piece.
Re: best way to remove window tint (GRIP KING)
Advance and AutoZone sell the kit that comes with the razor blade and mix that will get window tint off no problem.
Re: best way to remove window tint (cannan)
I just did this. Although I work at Mazda it was easy for me to get this stuff but it shouldn't be too hard at a automotive store. Get some solvent and scrub the crap out of it. Also make sure the tint is warm as it will be easier to remove (I figured this one out the hard way, 2hrs of scrubbing). If you got a defrost on the back then you just scrub like crazy. No razor blades on the back.
Re: best way to remove window tint (playalistic2)
when i peeled mine off it left some glue on the windows. "Goo Gone" took that right up! Plus it wont get you as high as some of the other chemicals you can use!
