Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Code P0113 cannot find IAT
Old 10-16-2009, 05:23 AM
New User
embdenb's Avatar
Default Code P0113 cannot find IAT
My 2005 Accord SE 2.4 engine is generating a P0113 code. According to the scan tool this is a Intake Air Temperature sensor fault. In visiting the Honda dealer they tell me the 2005 accord 2.4 does not have a IAT sensor. It has a Mass airflow, throttle position and temperature reader?
Can anyone help me to determine what sensor the P0113 code is referring to?
Thanks
embdenb is offline
Old 10-16-2009, 06:35 AM
92integraVTECgsr's Avatar
Default Re: Code P0113 cannot find IAT
What is the temperature reader they are talking about?
I would check the intake arm, intake box, and intake manifold for the IAT sensor. That is where you will find it if you have one.
92integraVTECgsr is offline
Old 10-16-2009, 06:55 AM
redbull-1's Avatar
For 4 cylinder (except SULEV), it would be on the intake tube as shown in the attached picture. For the 4 cylinder SULEV, it is a MAF/IAT sensor, located closer to the air cleaner.
redbull-1 is offline
Old 10-16-2009, 06:56 AM
New User
embdenb's Avatar
We looked at the intake from the air cleaner box to the throttle body. There are three sensors. None are identified by the dealer as an Intake Air Temperature sensor. The question is whether one of the current sensors is the culprit and the scan tool is calling it a IAT sensor when the 2005 model has something else. Example a P0113 error code on a 2005 honda refers to the mass air flow sensor and not the IAT sensor?
embdenb is offline
Old 10-16-2009, 06:58 AM
redbull-1's Avatar
Old 10-16-2009, 07:09 AM
redbull-1's Avatar
http://www.autobarn.net/maairflsecl1...te=google_base
Old 10-16-2009, 07:31 AM
New User
embdenb's Avatar
I do not have a IAT sensor as shown in your photograph. Does that mean I have the SULEV engine?
embdenb is offline
Old 10-16-2009, 10:34 AM
redbull-1's Avatar
It is probable that your Accord is a SULEV. If it doesn't have the IAT in the intake tube like the other picture, I would say that your's has a MAF/IAT sensor.
Old 10-16-2009, 11:00 AM
New User
embdenb's Avatar
The pic is exactly what my engine looks like. That sensor is approx $75.00 and I wanted to be reasonable sure before buying it. It was not called a MAP/IAT sensor by the dealer, some kind of "Reader" is I recall.
Thanks
embdenb is offline
Old 10-16-2009, 11:04 AM
redbull-1's Avatar
Before you buy a new MAF/IAT, go buy a can of the CRC MAF cleaner.
Unplug the electrical connector, remove the two philips screws, then pull out the MAF/IAT, and spray the cleaner on it. Let it air dry and reinstall. Many times they are just dirty.
You can find the cleaner at most auto parts shops like Kragens, etc.
Old 10-16-2009, 01:44 PM
New User
embdenb's Avatar
Thanks again
embdenb is offline
Old 08-13-2015, 05:44 PM
lazlong's Avatar
That piece is called an air flow meter (#20): AIR CLEANER (L4) for 2005 Honda ACCORD COUPE
lazlong is offline
Old 08-14-2015, 02:45 PM
poorman212's Avatar
^ So you are are answering the question from ~6 years ago ?
poorman212 is offline
ek9adrian
07-31-2007 10:38 PM
buddy jonez
04-04-2005 09:25 PM
Quick Reply: Code P0113 cannot find IAT
