Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2008 Honda Accord V6 Cylinder 3 misfire.
Old 01-05-2017, 04:38 PM
  #101
Old Member
GoLowDrew's Avatar
Default Re: 2008 Honda Accord V6 Cylinder 3 misfire.
You can now shut off the VCM and never have to deal with this again.
Old 01-06-2017, 06:59 AM
  #102
acurafan92's Avatar
Exactly, as there is no VCM off button what is the easiest way to have the VCM disabled apart of hacking the ECU?
Old 01-10-2017, 04:26 PM
  #103
Old Member
GoLowDrew's Avatar
VCM Muzzler. This guy on the Pilot form invented it. If you like, I can give you his info/link. Since posting it would be advertising. The quality is OEM, and it's the only one that I would recommend.
I've been using it for 30K miles now on my 2014. You'll looks some MPG mostly on the hwy. But awesome as all 6 cylinders are ready to go on command, as you wish.
Old 01-11-2017, 04:36 AM
  #104
acurafan92's Avatar
Thanks for providing this information.
It is interesting solution and easy to implement, good job Muzzler.
Old 09-05-2017, 09:31 AM
  #105
dopeyman06's Avatar
My 2008 Honda Accord v6 recently experienced this problem. The check engine light turned on and started flashing. The VSA and triangle also turned on (not flashing). And then the car started driving a bit rough. I pulled the codes and it came up with P0300, P0303, P0306. I called Honda corporate and they said that the issue was resolved by extending the warranty 8 more years. So basically the extended warranty/recall expired March 7, 2016. How can they put a time limit on a manufacturer defect? It's unknown when the problem will occur.
What can I do at this point to get Honda to fix this issue??
Old 09-05-2017, 12:48 PM
  #106
acurafan92's Avatar
Your statement is correct. As per Service Bulletin 13-078 powertrain warranty got extended to 8 years with unlimited mileage from the original date of vehicle purchase.
Old 09-06-2017, 11:07 AM
  #107
dopeyman06's Avatar
LOL. Yes. Thank you captain obvious. But I was asking if there was anything that I can do to get Honda to fix the car and honor the their recall.
Old 10-07-2017, 05:40 PM
  #108
MissMe's Avatar
Hi all, I got the dreaded P0303 misfire code.
I have read through all the posts, and my head is spinning.
I have an 08 Accord with 125k, am I correct in saying that Honda will not be fixing (for free) my misfire issues?
If that is the case, what would you suggest? A trade in?
I am at a loss. I had a 97 Civic that had over 200k and no problems, then an uninsured woman totaled it. I felt totally confident in my choice of a honda.
Old 10-07-2017, 06:22 PM
  #109
dopeyman06's Avatar
Honda will no longer do the job for free. I called corporate directly and pleaded/argued with them that it's a known issue and a manufacturer defect. Manufacturer defects shouldn't have a limited/extended warranty. Basically for the fact that you never know when the problem is going to come up.
BUT.... I took my car to a local mechanic and he said that the problem was the coils. So he replaced coils #3 and #6 and the car has been running perfectly. Before he replaced them, the car starting misfiring and running really, really rough.
So I would suggest replacing the coils first and go from there.
Old 10-07-2017, 07:09 PM
  #110
Stuff's Avatar
Replace the spark plugs before replacing coils. Also you can re-arrange coils to see if problem moves with coil before replacing.
Old 10-08-2017, 02:24 PM
  #111
MissMe's Avatar
We replaced the plug and coil pack for cylinder 3. It looked bad, like an ashtray. It was the only plug that looked this way. The rest looked new.
Is there even a possibility that Honda will disable the VCM?
Old 10-10-2017, 09:16 AM
  #112
melted_play's Avatar
Just get the VC muzzler. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F17 2249356977
It's a guy from Canada who makes a device that tricks your car into thinking it's not up to operating temp and basically VCM will not kick in. I've had it on my car for over 2 years now. I've noticed significantly less oil consumption.
CricketThomas
12
01-30-2017 06:37 PM
thecyclops
07-29-2013 08:35 AM
FunkTechNician
02-01-2011 02:31 PM
reloaded.sidd
02-15-2010 09:47 AM
96AccordEX
07-13-2006 09:40 AM
Quick Reply: 2008 Honda Accord V6 Cylinder 3 misfire.
