Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord not starting
Old 05-01-2016, 10:44 AM
MrBennett's Avatar
Default 2007 Accord not starting
I have a 2007 Accord and it is not starting. I had it sitting in a garage for about 2 months and nothing. I just put a new battery in and hooked it up and it only turns on some lights. When I put the key in, it does not turn over at all and I can't even get the car out of park. Any suggestions?
Old 05-01-2016, 03:02 PM
gabrielhermank's Avatar
Default Re: 2007 Accord not starting
Check the alternator.
Old 05-04-2016, 07:53 AM
CivicHxDude's Avatar
Please check your battery ground connections, sand them down to make sure connection is clean. A lot of people check the positive wires but never follow the ground wires and clean those connections.
Old 05-13-2016, 04:35 PM
NoHope's Avatar
Hey there
I had this issue initially with my honda 04, it was locked steering wheel and the key would not move anywhere and puff it broke in it. I had done some research but to cut costs if ur ignition is all good, your key is worn off or damaged. The honda dealer can only make u a spare/copy one but you gotta get the vehicle towed, there is no way around it. My situation is close to urs but my key broke inside my ignition, so best to take it to them, they will make u a fresh key with ur VIN, so be ready to supply them ur title and ur the owner.
Good luck
jpg16
07-30-2014 09:52 PM
allen honda
01-03-2012 03:06 PM
eascencio84
08-15-2011 01:14 PM
tony12moore7
07-23-2009 05:55 PM
MHonda06
05-16-2008 07:04 AM
Quick Reply: 2007 Accord not starting
