Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Honda Accord V6 ticking/fluttering noise
Old 09-21-2016, 04:02 PM
jonathancbrewer's Avatar
Default 2004 Honda Accord V6 ticking/fluttering noise
Hello All.
I have a 2004 Honda Accord EXL V6 Coupe with 218000 kms on it here. I recently became concerned with a slight fluttering or ticking noise which at first seemed to subside when the vehicle had warmed up. Over the last couple of weeks the noise has gotten worse. I originally thought the noise was isolated to a bad serpentine belt tension-er. I went to order one at a local parts store and the parts guy thought that the noise had been coming from the left upper bank of the timing cover. I sought some advice from a mechanic and he even thought that the noise was a faulty hydraulic tension-er. I removed the serpentine belt as well as the upper timing cover and inspected for play in the timing belt and everything appears to be tight. I started the engine and the noise was not present. Now I decided to go with my decision and replace the serpentine belt tension-er and the belt itself. Once I had everything back together I started the engine only to find that the same noise was present. Remove the serpentine belt and noise is not present. I am not a mechanic by any means. I can not isolate the noise to anything. All pulleys appear tight. Can the serpentine belt tension have any bearing on timing belt noise? I would appreciate any comments.
Old 09-24-2016, 05:34 AM
poorman212's Avatar
Default Re: 2004 Honda Accord V6 ticking/fluttering noise
If the noise goes away with the serp belt off, then it has to be something the belt is turning....ps pump, alt, ac compressor, ect. Re-check all of the pulleys - spinning them by hand and feeling for any "hard spots". I can't say any one pulley is more prone than the other so it is going to take some investigation.
Sorry, I know this isn't much help
JtranCrypto
12-17-2014 04:27 PM
chancekang
04-23-2011 03:28 PM
nfinite
12-06-2008 12:11 PM
zxracer3
07-01-2007 01:20 PM
Quick Reply: 2004 Honda Accord V6 ticking/fluttering noise
