wheel weights
Old 02-01-2002, 10:00 AM
HondaNewbie's Avatar
Default wheel weights
anyone know how much the honda accord '01 coupe EX alloy wheels weigh? I want to compare it to how much weight reduction I'll get from 18lb. 18" rotas.
Old 02-01-2002, 10:06 AM
SOHCArchangel's Avatar
Default Re: wheel weights (HondaNewbie)
its not so much the weight as it is dimentional inertia, the further out away from the center of the rim where all the weight will be the more inertia meaning the wheels will soak up so much power to get rolling and stay rolling, IMO i would not get 18's i would spend the money elsewhere
Old 02-01-2002, 10:11 AM
Default Re: wheel weights (SOHCkordVTEC)
yeah I had thought about that too...I was originally planning on staying with 15" but 18" would look pretty sweet....probably not worth it though, my kord needs all the help it can get so staying 15" would be better I suppose
Old 02-01-2002, 10:12 AM
yeah, just go up a lil bit in wheel width and get some better rubber,
Old 02-01-2002, 10:13 AM
New User
urbanlegend21's Avatar
contrary to popular beleif this is your best choice, you can make 15's look good on your accord too, it has a better tire selection and offers more performance
Old 02-01-2002, 10:20 AM
Default Re: wheel weights (urbanlegend21)
I do like how my stock wheels look but yeah I should get some that will improve my performance, and I don't know much but I guess width will help out my handling in that area without adding much weight. Plus, gunmetal would look so tight on my silver car...new wheels here I cooooome! Any suggestions for brands/measurements?
Old 02-01-2002, 10:25 AM
i would do 16x8"s im not to familliar with the 6th gens tell us your stock wheel and tire package and ill give you my take on it
Old 02-01-2002, 11:52 AM
H23 Power's Avatar
6th gen 4cyl have 15x6 with 195/65-15
[Modified by 01GSR, 2:52 PM 2/1/2002]
Old 02-01-2002, 12:06 PM
Default Re: wheel weights (01GSR)
ok in that case you can go 15x7 with 205/55/15's
or you can get a bit sillier like me and get 16x7's or 8" 225/45/16 =D
Old 02-01-2002, 12:07 PM
New User
i have 15 x 7
you would need a pretty big offset to fit 15 x 8 right?
Old 02-01-2002, 12:08 PM
i have 15 x 7
not necissarily there should be enough space for it to fit +45 should do the trick
Old 02-01-2002, 12:20 PM
15x7 is diameterxwidth I understand.....but what do the other measurements stand for? (xxx/xx/xx)?
Old 02-01-2002, 12:24 PM
New User
205/50/15
tire width/sidewall width/rim size
Old 02-01-2002, 12:35 PM
ahhhhhh...it's all so clear now
Old 02-01-2002, 12:50 PM
do you go to UM? i used to live in wheaton and takoma park.....
Old 02-01-2002, 01:24 PM
no I go to UMBC...but I will transfer to UM in the fall. Where do you live now?
Old 02-01-2002, 03:21 PM
Nick M's Avatar
You dont need 8" wide wheels to run 225s, you can stick them on 7"s. 15x6.5 Prelude wheels from the 4th gen fit 225 tires.
Old 02-01-2002, 03:58 PM
i live in sterling VA, i took a few classes at UMBC a while ago.....
nick...6.5" width wheels will not stretch the tire out to its fullest contact area so 7 or 7.5"
Old 02-01-2002, 06:55 PM
Honda318dx's Avatar
True, but it works, and the wheels are cheap...
Old 02-01-2002, 08:09 PM
Nick M's Avatar
Default Re: wheel weights (Honda318dx)
That was my original point. But yes you are right Misa.
michaelprice83
12-14-2008 08:12 PM
huge230
04-28-2007 06:52 PM
Klutch
10-05-2005 07:56 PM
Philbert
10
02-22-2004 11:34 PM
jg
08-20-2002 08:20 AM
Quick Reply: wheel weights
