what fuse to pull to disengage ABS?
New User
what fuse do i pull to disengage ABS, i see the box under the hood but theres 4 fuses and a relay inside it, not sure which to pull.
Re: what fuse to pull to disengage ABS? (Kazmans94cord)
if you only want it to be off for a one time thing and then back on next time you drive, put the E-brake on just one click, about 30 seconds or so the ABS light comes on, and the ABS is disengaged. Take off the e-brake and off you go.
