Turn Signal Flasher Location
I am having a bit of a problem. My turn signals stopped working the other day. My hazards work just fine, and when I lock and unlock the car using the keyless entry remote, the lights flash as they should. I took it to advance to find out what part I need to fix my problem and they told me that my flasher needs replaced. So I buy the $10 flasher...and search in my car for the "dead" one to replace. I found it down by the fuse box, swapped it out...problem not solved. So I return into the store and the man informs me that there are two flashers...one for my hazards, and one for my turn signals, the one I found must have been the one for my hazards and there should be a second flasher for my turn signals somewhere in the dash. I cannot seem to locate a second flasher ANYWHERE. Anyone who might be able to help me locate the hidden "turn signal flasher"...greatly appreciated...
--Gordi
aim - HondaB0i94
e-mail - Gordi6591@gmail.com
--Gordi
aim - HondaB0i94
Re: Turn Signal Flasher Location (Gordi2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gordi2 »</TD></TR><TR><TD CLASS="quote"> I cannot seem to locate a second flasher ANYWHERE. Anyone who might be able to help me locate the hidden "turn signal flasher"...greatly appreciated...
Good luck with that, there is only one relay to control hazards and turnsignals. I'd test the switch if it was mine.
Re: Turn Signal Flasher Location (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Good luck with that, there is only one relay to control hazards and turnsignals. I'd test the switch if it was mine.</TD></TR></TABLE>
I had a similar problem in the past. I would test the switch as well.
Hey the Turn Signal Flasher is located above the fuse box under the driver side dash. It's a little square black relay. It should be labeled
Re: Turn Signal Flasher Location (air_rock)
Well thank you all so much for your prompt replies. I am unfortunately going to be taking it to get it checked because it is getting to a point where my limited knowledge of cars is stunting my progress and I need it fixed NOW...would hate to get a ticket or even worse, in an accident....because i was too stubourn to dish out the cash....
Thanks again!
--Gordi
Thanks again!
--Gordi
cb1999nj
12-18-2005 02:26 PM
