tranny fluid
tranny fluid
on a 4th gen how do i change the transmission fluid?
someone told me id only drain a third if i just uncapped it and let it drain out cuz its still stuck in the tranny when the car is off?
can someone clear this up
Re: tranny fluid (KillerElfboy)
When changing the tranny fluid, only 1/3 of the fluid actually drains out. So to do a better job of replacing the dirty fluid, you should change it 3 times, with a short drive between each change. Use only Honda ATF-Z1, with no additives.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerElfboy »</TD></TR><TR><TD CLASS="quote">how many bottles should i use each time i change it?
like to do the whole thing am i gonna need a 3 bottles (1 bottle for each 1/3 change)</TD></TR></TABLE>
you use up around 2-2.5 quart each time.
Blacknight117
30
07-03-2011 07:25 AM
