Towing capacity of 1994 accord LX?
Hey guys I do not have a manual so please help me out here. I am going to minnesota and I want to know how much I can tow with my car. I was thinking about towing a 5*8 uhaul trailer and put what I have in there
a couch
TV
dishes
Bed
Pocket bike
Table chars
computer and monitor
clothes
a couch
TV
dishes
Bed
Pocket bike
Table chars
clothes
wow you would think someone knows the answer to this q..... but I guess not. I called the Honda dealer and they state 2000 lbs and to drive in 3rd grst
Re: (YeuEmMaiMai)
I towed a 1600lb car with my 97 Accord SE Auto up and down hills with no problem just start off in the lower gears with the automatic. Im assuming the car was 1600lbs. It was a 1984 Corolla Hatchback SR5. Overall it was not a problem. Also I had 3 passengers including myself in the car. The brakes might overheat a little quicker due to higher momentum. Just anticipate the braking early. Shoudn't have a problem with 2k lbs. Good Luck Also all of your moving items shouldn't be equal to 2k lbs. Luckily theres no snow either right now.
Re: (Charri)
I will add a hitch and tow a uhaul trailer. I am hoping for about 20mpg and I do not plan on using 4th gear on the tranny so the fastest I will be able to go is about 55mph.
edit: How far did you tow the car? I am going about 650 miles.
Modified by YeuEmMaiMai at 9:25 AM 7/28/2005
i would also add an aftermarket tranny oil cooler... & perform a drain/refill before/after the trip... but that may be excessive.
that little heat exhcanger built into the radiator may be sufficient & may just do the ATF drain/refill...<shrugs>
Re: (ricebike)
Yeah if it is an automatic I would add a tranny cooler. Changing fluid before and after the tow isnt really nessasary in my book because if the cooler is there the tranny should stay somewhat cooler than it does under normal driving even with the extra weight.
I'll be driving at night and I really do not want to be adding a cooler to the car. I might even go with a 4*6 trailer if I can find one. (not likely)
Arian
11-07-2016 11:55 AM
hondalife75
06-05-2010 07:30 PM
