timing belt replacement question
Old 09-24-2011, 12:41 PM
jayzeno's Avatar
Default timing belt replacement question
what all do i need to replcae when replcaing a timing belt? i have never done one my self and want to buy the parts and have a shop do the labor but do not know what else i should change while the timing belt is out? the car has about 195,000 miles on it and i bougfht it at 125,000 miles and never have had to change the timing belt or water pump.. what is the suggested maintence or replacement parts needed for a car with my milage? i have a 97 accord lx 5 spd.
Old 09-24-2011, 12:50 PM
jdmcertified909's Avatar
Default Re: timing belt replacement question
read thru out this thread there's one that focuses on timing belt area and what you should replace.
Old 09-24-2011, 12:56 PM
Icon3 Re: timing belt replacement question
here you go https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/ this was a few thread below yours
exb18c1's Avatar
There a kit available that contains most of the stuff.If I,m not mistaking those model were affected by TSB which tell to install a retainer clip for balancer shaft seal.It's like 5$.Change the 3 seals at the same time and make sure( when everything will be out ) the oil pump housing gasket isn't leaking.I always check ignition timing after doing a timing belt job and resetting the adaptive memory.
P.S. Get the original parts.
shrekfiona
17
05-31-2013 11:04 PM
bandit67
15
07-29-2008 09:33 AM
H22CD7
05-20-2007 07:23 AM
hatchydude
07-17-2005 04:49 PM
PetroGuyX
07-30-2003 12:29 PM
Quick Reply: timing belt replacement question
