JDM H22a Knocking??? Still???
Old 02-24-2006, 04:07 PM
godsider's Avatar
Default JDM H22a Knocking??? Still???
Hi i was posting a while back trying to find bearings for my H22a. Found a set that i bought from tunerschoice.com that are ACL rod and main bearings. My friend installed them and put a new oil pump in to, Then when we cranked it over it started but there was a knock that was worse and faster then before?? Before we installed it only knocked a little bit at high R's Now its worse and i would like to know if anyone could hepl out or have any suggestions.
Thanks
God Bless
Old 02-24-2006, 04:15 PM
P_Adams's Avatar
Default Re: JDM H22a Knocking??? Still??? (godsider)
Does this knock change with engine tempurature? IE: Loud cold, quiets down when it warms up? or visa-versa.
There are several items which can cause knock-like noises.
Main Bearings
Rod Bearings
Thrust Bearing
Pistons (collapsed skirts)
Piston Pins
Loose Flywheel/Flexplate
Timing Belt tensioner
Need mo' hints Maybe we can put a handle on this.
What oil clearance specs did you set up for the crank/bearing clearance?
P
Old 02-24-2006, 05:35 PM
godsider's Avatar
The noise stays the same when cold or hot and im using 5w 30 oil, also everthing is tight but the thrust bearing was not replaced but it was not bad from the start.
Old 02-24-2006, 07:43 PM
98accrd's Avatar
Default Re: (godsider)
Did you use plastic-gauge to check the bearing clearances?
Old 02-24-2006, 09:45 PM
godsider's Avatar
No i just bought the ones that come standerd that would be the Green OEM style.
Old 02-24-2006, 09:59 PM
YeuEmMaiMai's Avatar
take the engine out of the car, tear it down and put it back together making sure that everything is in spec.
Old 02-25-2006, 08:19 AM
godsider's Avatar
that would be one way to really fix it but i hopeing for an easyer way. any other options or could be's guys?
Old 02-25-2006, 09:07 AM
P_Adams's Avatar
Smart *** answer:
Brick on the accellerator pedal
Dr. Widget's Mechanic inn'a Can
Only answer:
You're taking about tolerances measured in thousands of an inch when it comes to assembling an engine. There's only one way to do it - the long, tedious drawn-out proceedure of measure, measure and measure again before assembling. keeping eveything absolutely spotless and forgetting the "oh, that's good enough" attitude. Make the commitment, or pay to have it done right.
Old 02-25-2006, 03:03 PM
godsider's Avatar
Sounds like the best thing i have heard yet!, And prayers are deeply appriciated, my name is Aaron. if any other suggestions let me know. Ill keep everyone posted as we re taer it appart and re put it back together again hopeing something just was loose.
God Bless
99siRACER
05-03-2012 04:41 AM
VBitter
05-15-2011 04:22 AM
qpe
03-01-2011 11:28 PM
Root79
03-30-2005 09:51 AM
Frankie324
01-29-2003 07:07 AM
Quick Reply: JDM H22a Knocking??? Still???
