2001 Honda Accord V6 revs to 5k rpm when starting
Old 02-03-2019, 04:52 PM
Helldawg's Avatar
Icon5 2001 Honda Accord V6 revs to 5k rpm when starting
I recently had to change the Idle air valve for the surging RPM problem. Got it changed and was running smoothly. I noticed the accelerator cable casing was splitting out so I ordered a new one to replace it. Now when I start the car it jumps to 5000 RPM and stays there. I have adjust the cable so it has slack and even unhooked it and still have the same problem. Any ideas?
Old 02-04-2019, 02:42 PM
Pauls94accord's Avatar
Default Re: 2001 Honda Accord V6 revs to 5k rpm when starting
Your throttle may be stuck open because you tightened the intake hose too much. Loosen the connection right before the throttle body and see if that goes away. I did that when I cleaned out my idle valve the first time.
Jack jaxz
Engine Management and Tuning
03-30-2016 04:15 AM
dhoff024
07-23-2015 02:15 PM
AtoZ
10-13-2009 06:50 AM
poor_red_neck
07-28-2007 07:26 PM
1990AccordBoy
03-17-2007 03:47 PM
Quick Reply: 2001 Honda Accord V6 revs to 5k rpm when starting
