stock wheel size??
Old 11-12-2004, 08:34 AM
optimis's Avatar
Default stock wheel size??
Are the stock wheels for a 4th gen accord 15"?? I'd like to upgrade to the 11.2" rotors w/ the dual piston calipers, but I don't know if they'll fit under stock wheels.
BTW search returned nothing
Thanks
Old 11-12-2004, 10:15 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: stock wheel size?? (optimis)
I'm not 100% positive but I think the stock rims on the 90-93 Accord were 14". You could always get a set of 94-95 EX rims or something if you want to keep it stock.
Old 11-15-2004, 09:13 AM
maroonaccord2.2's Avatar
You are going to have to go to at least a 17" wheel. That big-a$$ caliper is going to increase the overall circumference of your brake kit, you are most likely not going to clear that with an OEM wheel.....
Old 11-15-2004, 09:31 AM
H-T Order of Merit
Default Re: stock wheel size?? (maroonaccord2.2)
correct me if I'm wrong but don't the AV6 and Legend dual-pistin brake swaps have 11.2" rotors? I'm almost positive they do and that I've seen the Legend dual-piston caliper swap on an Accord with stock 94-95 EX rims which are 15". Also, don't the 95-97 Accord V6 come with 15" rims stock? This is what I assumed he was going to be doing. Now if he plans on using some aftermarket caliper then I don't know, I just assumed he was going to use an OEM set-up that would allow the use of 15" rims.
Old 11-16-2004, 01:09 PM
optimis's Avatar
Default Re: stock wheel size?? (TouringAccord)
Yes the rotor size would be 11.2" and the calipers would be off a legend. It's the swap that's been done on accordinglydone.com. I'm just now thinking that I may have 14" rims and be unable to do the swap.
I'll at least try for the hub over rotor so when/if I do get bigger wheels I'll be able to upgrade fairly easy.
A little off topic but sparco are pretty good wheels right? I've found a set I like and just wanted some input. Thanks all
Old 11-16-2004, 02:12 PM
H-T Order of Merit
Thats what I thought. It sounded like you were doing one of those swaps. Rotor over hub would be nice to do as well.
As for Sparco wheels though, I don't know anything about them.
Old 11-18-2004, 01:18 PM
optimis's Avatar
rotor over hub is what I meant to say.
Anyone else know about sparco wheels?
Old 11-18-2004, 03:22 PM
CWestAccord's Avatar
rediculously light, and made for oversized brake setups. but look forward to paying out the wazoo for a set of 17s or anything of decent size. true Volks would be cheaper.
EkDave
07-09-2008 04:21 PM
Kents-Accord
11-25-2005 09:52 AM
Jaguar
04-01-2003 04:19 AM
accordy1780
09-30-2002 06:13 PM
Quick Reply: stock wheel size??
