should I replace the timing belt on my 98 accord?
I recently acquired a 1998 accord ex v6 from an elderly couple who didn't drive it much, and it only has 14,000 miles on it. I know Honda recommends replacing the belt at 105,000 miles but this car is over 11 years old. Should I go ahead and get the belt replaced now or am I likely good for a while? thanks
Re: should I replace the timing belt on my 98 accord?
Wow... 14,000 miles on it... thats amazing!
Oh, and I agree with the others about checking everything out. If everythings good to go then you have quite a gem of an accord on your hands (beside it having an automatic, but its still ready to go a lot of miles)!
Also remember to change water pump and seals and outer belts when you change your timing/balancer belt. I would also replace thermostat and flush radiator system at the same time. Also I would bleed the brake lines with fresh clean honda break fluid as well change transmission fluid. New fuel filter well worth the effort.
This may cost a bit of cash but not bad if you go online and get some rebates for oil and transmission fluid. I like to use Pennzoil Platinum Synthetic in all my cars. I would stay with Honda Transmission Fluid.
Good luck with your "new car". In 2006 my late dad left me a 1996 Pontiac Bonneville with only 18,000 miles and I changed everything so I would feel good about driving it anywhere. Now that is a good american car.
flexylexy
12-19-2020 02:21 AM
1yesfan
03-11-2015 07:54 PM
naix
09-14-2009 06:22 AM
