F22A6 motor on H22 block ? Possible ?
Hi everyone,
I know this might sound quite strange but I wanted to know if an F22A motor can be rebuilt onto an H22 block.
My F22 has a crack betweeen cilinders 3 and 4. I've looked but there's not much hope I can find another block to have it swapped.
I am not still sure with my block can be repaired but if it turns out unrepairable, I'm stuck in a dead-end.
So, this is why I ask this ... can anyone confirm if I could have my engine rebuilt on a H22 block ? Everyhing else would be from the F22 ( crankshaft, head, etc etc ... ) but I really needed to know this to try and make a decision on what to look for.
Thanks for your help.
Re: F22A6 motor on H22 block ? Possible ?
NO POINT!!!! I assume you probably want to do this because you blew your F22 block and have an H22 handy?? If not,none the less its still not gonna be a good ide. Just do a F22 block with H22 head. AKA G22 or G23. It will be cheaper in the long run anyways.
The thing is ... F22 blocks are almost impossible to find. I do not have any H22 available as well but if I look for one, I'm sure I can find one over here ( and almost sure I won't find any F22s as well ).
Not because I want to but because I need to ... if I was to build a mongrel, it could NOT be with an F22 block.
I'm still waiting to find out if mine can be repaired or not ... first of all.
