refrigerant question
Old 02-26-2007, 11:56 AM
cityslicker1606's Avatar
Default refrigerant question
my air conditioner stopped blowing cold so i bought some 134a refrigerant and i want to ask how do i put it in, this is kind of a stupid question but i dont know **** about a/c's. please help.
Old 02-26-2007, 12:36 PM
YeuEmMaiMai's Avatar
Default Re: refrigerant question (cityslicker1606)
save yourself a headache and have a professional do it for you.... overcharging your system can lead to failure and or loss of cooling performance as the system cycles on and off due to high pressure cut out.
Old 02-26-2007, 01:10 PM
Perfectionist's Avatar
Default Re: refrigerant question (YeuEmMaiMai)
Not to mention the chance of losing your hand when the can of refrigerant frags on you.
Old 02-26-2007, 02:09 PM
Default Re: refrigerant question (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Not to mention the chance of losing your hand when the can of refrigerant frags on you.</TD></TR></TABLE>
alright you scared me out of it i will just take it somewhere, thanks for the advice
Old 02-26-2007, 03:08 PM
AJ06's Avatar
lol
Yea mechanics use some **** and then they check the pressure, and stuff...
I also didnt try :D
Old 02-27-2007, 02:58 AM
AccordEX1991's Avatar
Default Re: (AJ06)
Your 92 accord used R12 frm the factory. Yayyy!
You need to do a R134A retrofit before you can put that R134A refrigerant.
I don't think you are equipped to do that.
Old 03-12-2007, 07:33 PM
Default Re: (AccordEX1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordEX1991 &raquo;</TD></TR><TR><TD CLASS="quote">Your 92 accord used R12 frm the factory. Yayyy!
how can i tell if my car has already been converted. or if it stil has r12
Old 03-12-2007, 07:44 PM
runderwo's Avatar
Default Re: (cityslicker1606)
If the valve on the charge hose fits, it has been retrofitted. If it is not, then it will not. Retrofit involves removing all of the R-12 with a recovery machine (or releasing it and making an ozone hole), replacing the dryer, vacuuming the system to remove the moisture, and charging with a POE oil charge and 80% (of the factory R-12 charge in lbs) of R-134a. You MUST add POE oil or the compressor will fail because R-134a will not carry the mineral oil in a R-12 system, and PAG oil (the factory R-134a type oil) does not get along with R-12 retrofits.
S2KJ55
Honda S2000
06-12-2006 09:56 AM
danielm3
Welding / Fabrication
19
10-04-2005 12:09 AM
c2etalon
14
06-19-2004 03:06 AM
Brian-Brian
06-28-2003 05:43 PM
zer0zer0 TypeR
05-09-2003 12:33 AM
Quick Reply: refrigerant question
