Recently changed timing belt....Makes a whining noise....
I went to my local car shop and had them do a timing belt change on my car. Ever since then every time I drive the car by either revving it up or shifting at high rpms it makes this whining noise almost like a superchager. My best guess is that the belts are probably too tight. Someone else told me that its possible that the alternator is going out. I already went back to them once and they said that its perfectly normal. Honestly I think they did a half *** job because the car is loud even at idle. I can tell them to fix it but they keep saying there no problem when I know there really is. What do you guys think?
Re: Recently changed timing belt....Makes a whining noise.... (hondadude)
Which belt is that? Couldnt it be any of the belts? I had them all replaced at once.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">I'd guess the counterbalance belt is too tight</TD></TR></TABLE>
^^^ most def
^^^ most def
Re: Recently changed timing belt....Makes a whining noise.... (hondaracin24)
+1 for timing belt/balancer belt is too tight
get it corrected ASAP.
hey honda
i have the same issue with my 94 accord, after i had my timing belt done it made this whining sound or like u said a supercharger anyway my water pump is starting to leak gonna have to spend money to get it re-done, i were u i'd report them to the better business bureau. by the way where in NH sue to live there.
Re: Recently changed timing belt....Makes a whining noise.... (Jmumblez2001)
i had the same problem, everytime i start my engine in the morning it makes that noise, but when the car warms up it stops.
Re: Recently changed timing belt....Makes a whining noise.... (Duane_in_Japan)
hey my car, 91 accord ex, makes a similar noise although I would describe it more as a remote control car whine. Now I dont hear it because my exhaust has broken just after the resonator and its held up by a chain of hose clamps. It sets off car alarms when I drive into parking lots now lol. Anyway assuming this is a too tight balance belt does this mean I may have a limited lifespan on the car or is it a minor problem?
Re: Recently changed timing belt....Makes a whining noise.... (PoppinOppen)
what's the process of adjusting this?? I had a firsetone guy tell me the only way to fix it would be to just go ahead and tear everything down and put a new one on while they were at it. this being ridiculous since i just paid 200 dollars to have it done about 15k miles ago. Said it would be about 500 "but the new timing belt is the cheap part.." Is there any way of adjusting this???
Re: Recently changed timing belt....Makes a whining noise.... (HondaINTEGRAted)
Your belt should be manually adjusted for its tension, I dont remember any Honda hydraulic tensioners lately, it will require some disassembly of the timing covers and other items patially covering these timing covers then just some untweeking of the overtightened belt via the tensioner pulley and put it all back together. A novice with a Haynes manual can do it in a few hours no problem as long as the crank bolt comes out and you have already borrowed needed tools from Autozone.
Still recommend accessory belts are removed and see if noise is still there.
Re: Recently changed timing belt....Makes a whining noise.... (lxaccord51oxl)
i have this same issue currently. is this a problem? what should I do about it?
cr00klyn718
09-05-2003 12:53 PM
