Replacing rotor on a 93 Accord, have questions...
Old 06-24-2009, 12:46 PM
LandHard's Avatar
Default Replacing rotor on a 93 Accord, have questions...
sorry about bumping an old thread, but i can't make a new one yet. i attempted to replace the rotor on my 93 ex yesterday and ran into this same problem. i an confused about one thing though:
can the hub and rotor be removed (and a new rotor installed) once the spindle nut is removed, or does the whole axle have to come off?
what are the basic steps to replace a rotor?
i got this far:
jacked car up/removed lugs/removed wheel
removed caliper & brake pads
removed the 4 hub bolts
Old 06-24-2009, 01:14 PM
The-Kid's Avatar
Default Re: 36mm spindle nut from hell..............HELP PLEASE!!!
i got this far:
Check out the Accord FAQ Sticky, and find the link to changing out the front rotor. The pictures will give you a good idea of what's involve.
It's true that the 4 hub bolts holds the rotor, but since this is a hub-over-rotor design, you need to remove or partly remove the steering knuckle...
(90-97 Accord have hub over rotor design, starting 98+, this design is no longer used)
Old 08-08-2009, 12:58 PM
karrar55's Avatar
Default Re: Replacing rotor on a 93 Accord, have questions...
I got a question! to take off the spindle nut, is the threads counter clockwise? because I cant seem to remove the nut! help would be appreciated! thanks
Old 08-08-2009, 10:14 PM
New User
love4thecb's Avatar
Hey karr, its jus the standard lefty loosey righty tighty, it may just be hella tight!
Old 08-08-2009, 10:38 PM
slammed4thgen's Avatar
yes i had one that i put 500lbs of tq on and it still wouldnt budge.
i actually snapped my 1/2 breaker bar trying!
rent a 3/4 in set from oreillys or somewhere and it should do the trick.
mine i ended up cutting with a cutting wheel because nothing would get it to budge.
if you end up having to do that, cut in to the nut until its very thin and then take a chisel and crack it a few times...it should break the small portion of metal left without damaging your axles threads.
op. look into a roh(rotor over hub) kit from tasauto...it comes with the bearings and hubs already pressed so its basically a bolt on affair.
Old 08-09-2009, 12:44 AM
karrar55's Avatar
thanks guys!! ima look into buying those hubs! is that place the only place that sell them???
Old 08-09-2009, 03:48 AM
conker's Avatar
I had a bugger of a time with it also till I got a slider with a 3/4 drive:
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
drivers side
- slide the socket to the middle and put the bar on the nut horizontal
- 3 food pipe on left side, put your **** on it
- floor jack under right side of bar
- friend on brake pedal
- few pumps of the floor jack, off it comes.
Old 08-09-2009, 04:57 PM
karrar55's Avatar
once i talk off the spindle nut, do i have to use a air chisle to take off the spindle???
Old 08-10-2009, 03:42 PM
AccorDitroN's Avatar
no have someone push down on the hub and pull out the spindle on the rotor....use an ext. and hammer it into the spindle very lightly but it wont come out all the way you need someone to push down on the hub...
Old 08-12-2009, 07:25 AM
96redexcivic's Avatar
Icon6 Re: Replacing rotor on a 93 Accord, have questions...
Hey look like you got this under control, but you don't have air impact that will do the job for the spindle nut and for the hub chisel and hammer all the around will do the job, "Sound like somebody having fun" Good Luck
Joetravelall
02-20-2007 03:25 AM
RAYThOM
09-22-2006 11:10 PM
cincispeedemon
08-04-2006 05:48 AM
cottonfamily05
05-13-2005 08:37 PM
Quick Reply: Replacing rotor on a 93 Accord, have questions...
