H23 trans to an F23 block
Old 03-24-2014, 06:48 PM
devxdev's Avatar
Default H23 trans to an F23 block
First off will the h23 tranny work in the F23 block, I'm in the middle of the G23 build on my 01 and getting off the auto trans is next on my list. I have a perspective tranny for a steal comes with shift linkage too.
So if it does fit is there anything other than the clutch pedal that I'm overlooking for the swap list?
If the h23 doesn't fit is there a model that does? I've heard b16/18's do but cannot find any proof.
Thank you all for you time, y'all helped me on my ls swap last time!
Old 03-24-2014, 07:10 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: H23 trans to an F23 block
H22/F22 and F23/H23 bellhousings are the same. Should be no problem bolting the two together.
Old 03-24-2014, 07:19 PM
devxdev's Avatar
Awesome thanks! Picking it up now
Old 03-24-2014, 07:22 PM
MM Gruppe B
MAD_MIKE's Avatar
On a note, make sure it is NOT a ATTS trans, found in certain last gen Preludes.
Old 03-25-2014, 01:14 PM
chrisnick's Avatar
Related question since I'm doing a similar swap, are the throw out bearing and lever/ arm the same?
Old 03-25-2014, 02:40 PM
MM Gruppe B
MAD_MIKE's Avatar
Clutch forks are the same,
Both= 22821-P0S-000 FORK, CLUTCH RELEASE
but the bearings carry different part numbers
Prelude= 22810-P21-003 BEARING, CLUTCH RELEASE (FUJIKOSHI)
Accord= 22810-PX5-J02 BEARING, CLUTCH RELEASE (KOYO SEIKO)
Old 03-25-2014, 05:06 PM
chrisnick's Avatar
Since the fork is the same, and the clutches are interchangeable, I'm guessing h clutch+h throw out and f clutch+f throwout? Is look at majestic right now to compare pressure plate and clutch part #'s, but I'm at work. Appreciate it, Mike.
777DYNASTY
12-28-2009 11:54 AM
itsapeace
12-14-2006 02:02 PM
xxmastermindxx
07-26-2006 07:53 AM
Goinfasterthanu
01-22-2005 11:58 AM
97lx
09-20-2004 03:27 PM
Quick Reply: H23 trans to an F23 block
