wheres the themostat on a 93 accorrd
Old 04-10-2005, 04:08 PM
INSANITY's Avatar
Default wheres the themostat on a 93 accorrd
Posting this for my step father he cannot find the themo on his 93 accorrd
Old 04-10-2005, 08:14 PM
AmonDin's Avatar
Default Re: wheres the themostat on a 93 accorrd (INSANITY)
There are two hoses for coolant to and from the radiator. The top one flows to the radiator, and the bottom one flows from the radiator to the back of the engine. The thermostat is in the part that the bottom radiator hose connects to. I believe there are two bolts that hold it to the head. If you need more help, just let me know.
Old 04-11-2005, 07:31 AM
Stripped Honda's Avatar
Default Re: wheres the themostat on a 93 accorrd (AmonDin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmonDin &raquo;</TD></TR><TR><TD CLASS="quote">There are two hoses for coolant to and from the radiator. The top one flows to the radiator, and the bottom one flows from the radiator to the back of the engine. The thermostat is in the part that the bottom radiator hose connects to. I believe there are two bolts that hold it to the head. If you need more help, just let me know.</TD></TR></TABLE>
you are correct ... the best way is to just remove the hose and then use a 10mm socket to remove the 2 10mm bolts when you install the new thermostat remember that it has a up position so if you dont put it right they will leak
ILcrxsi1
03-29-2007 03:14 PM
rewerbcrx
12-25-2006 08:42 PM
icedlee
05-07-2005 02:14 PM
B18Redline
12-02-2004 09:35 AM
Quick Reply: wheres the themostat on a 93 accorrd
