p0780 accord "Problem in Shift Control System"
Old 04-28-2005, 11:51 AM
alsarabi's Avatar
Default p0780 accord "Problem in Shift Control System"
I'm getting code p0780 "Problem in Shift Control System" for 2001 automatic accord. Does this mean the clutches in the transmission are bad? I need suggestion please as I cannot think where else to start.
Thanks!
Old 04-29-2005, 01:23 PM
deserthonda's Avatar
i doubt your clutches are bad ...first thing i woud do is remove the lock-up control solenoid/valve shift control solenoid clean out passages sometimes screen get clogged ,,put back together clear code and test drive
Old 04-29-2005, 03:46 PM
metric's Avatar
Default Re: (deserthonda)
how many miles are on it?
Old 05-30-2005, 01:11 PM
daver's Avatar
Default Re: p0780 accord "Problem in Shift Control System" (alsarabi)
did you get it fixed?
Old 11-30-2006, 03:22 PM
honda genome
Guest
Posts: n/a
Default Re: p0780 accord "Problem in Shift Control System" (daver)
did u fix this or what, similar prob. here....
Old 11-30-2006, 06:54 PM
hondadude's Avatar
Extended warranty
mina
12-28-2017 09:55 AM
Ruizj2195
09-09-2017 06:31 AM
garbagehonda
09-17-2010 03:12 AM
espedito
01-04-2010 02:45 PM
Quick Reply: p0780 accord "Problem in Shift Control System"
