ONLY 17mpg on my 1999 accord ex 4 cylinder
Old 04-17-2008, 04:16 AM
cluelessaboutmyhonda's Avatar
Default ONLY 17mpg on my 1999 accord ex 4 cylinder
this car has averaged only 17mpg only my highway and some city driving since I got it 4 months ago. I'm not heavy on the gas or brake pedal. the tire pressure is good. Could someone give me some suggestions? I get about 300 miles per tank on a 17 gallon tank and don't fill up untill the gas light comes on. PLEASE HELP! I can't keep spending $50+ to fill up every week.
Old 04-17-2008, 04:46 AM
thabao's Avatar
Default Re: ONLY 17mpg on my 1999 accord ex 4 cylinder (cluelessaboutmyhonda)
that sounds about average haha, my car got about 300-350 when i first got it, it's a 94 accord lx.
have you changed air filters? spark plugs and wires? any kind of tune up when you got it? simple tune up can help. i'd also seafoam the car, that help me alot.
my car has an long ram intake, header, new plug and wires, hi flo cat and a cat back. then i clean out the TB, FICV, and seafoamed it, i average about 330-410 miles a tank now, big increase huh?
just try to clean out somethings and tune it up, you can free alot of miles up.
Old 04-17-2008, 05:12 AM
H-T Order of Merit
TouringAccord's Avatar
you don't actually run the tank til the light comes on then then fill up, take the miles driven and divide it by 17 for the tank size do you? If so, you are doing it wrong.
First, don't drive it until the light comes on, fill up sooner. As a general rule I fill up when I get to about 1/4 tank.
When you get gas next, fill it all the way up and reset the trip in the gauge cluster. On your following fill up, fill up all the way again. Now take the amount of miles you drove on that previous tank and divide it by the total amount of gas it took to fill the tank up. For example... 365 miles driven and 15.3 gallons of gas put into the tank would give you 23.9 mpg.
Old 04-17-2008, 09:08 AM
not-a-stang's Avatar
Default Re: ONLY 17mpg on my 1999 accord ex 4 cylinder (TouringAccord)
My 95 is being a gas hog too. I already pumped $40 this week and its gone!
The only thing I could do now is give it an oil change......oh well.
Old 04-17-2008, 10:58 AM
H-T Order of Merit
Default Re: ONLY 17mpg on my 1999 accord ex 4 cylinder (not-a-stang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not-a-stang &raquo;</TD></TR><TR><TD CLASS="quote">My 95 is being a gas hog too. I already pumped $40 this week and its gone!</TD></TR></TABLE>
could just mean you drive a lot...
Old 04-17-2008, 01:52 PM
FunnyVictor86's Avatar
now since ultra low emission vehicle is better for the enviornment due to it having lower emission ... does that make the ulev vtec eng. better on gas than a regular a vtec eng.? ... just curious
Old 04-17-2008, 03:54 PM
EuroKing99's Avatar
Default Re: ONLY 17mpg on my 1999 accord ex 4 cylinder (FunnyVictor86)
i say its time for a full service tune up. the mileage will also change with a bunch of little stuff, tire pressure, weight in the trunk, pedal to the metal, etc
Old 04-17-2008, 05:29 PM
GS-Rcivic's Avatar
Default Re: ONLY 17mpg on my 1999 accord ex 4 cylinder (EuroKing99)
Thats prety low man. I get 24-25mpg regularly with cith and 80mph drives on my 00 EX ULEV v-tec. I would say plugs wires and maybe fuel filter.
Old 04-17-2008, 06:36 PM
mattkins91's Avatar
I have the same problem with my 93 ex. Ive tuned up everything i can think of except my injectors wich im going to do this weekend.
Old 04-17-2008, 07:40 PM
get yourself a bottle of lucas injector cleaner at your local autozone
Old 04-17-2008, 09:48 PM
Heat's Avatar
Replace the spark plugs (should be replaced every 30,000 miles on that car) as well as the wires unless the wires look to be relatively new. Replace the air filter. Make sure your tires are properly inflated.
Are there mods on the car? And I get around 27 to 28 mpg in mixed driving in my '99 I4 Accord, 33 to 34 mpg on the interstate (about 72 mpg).
And by any chance is your car a DX model? Those didn't have VTEC engines which, I think, would affect your mileage to some degree.
By the way, those cars are notorious for having inaccurate speedometers (will read high). The next time you are on the interstate, use a stopwatch to get the average time between miles while the cruise control is locked into various speeds. Divide the average time in seconds per mile into 3600 and you have your actual speed in miles per hour. My car reads about 4 to 5 mph high when I'm in the 70s (it'll read 75 when I'm doing 71, will read 80 when I'm doing 75). And it's not adjustable, it is what it is.
corkss
11-10-2008 07:42 AM
Hbcueducated
03-03-2007 07:04 PM
alexb16hb
11-18-2004 10:46 AM
NiBlazed
10-26-2004 07:07 PM
r4m3n
04-30-2002 06:59 AM
Quick Reply: ONLY 17mpg on my 1999 accord ex 4 cylinder
