Accord 2001 wont start and stalls
Old 12-12-2009, 10:27 PM
New User
sam786's Avatar
Default Accord 2001 wont start and stalls
Hi Guys
Need some advise please.My car does not start especially when cold. The engine management light and the green key light do not come on when it has starting issues, but when these two lights come on and off the car starts fine and drive. It also cust out whilst driving.
What I have done so far:
Changed main relay- no change
changed ignition switch- no change
changed battery- no change
got all connect uner dash checked for loose connections- no problems
Checked the engine management system. it records the following faults
P0700,P0763,P1753
A frined of mine told me that all three of the above still indicates ignition switch issue? is this correct.
My auto box is fine changes through the gears just fine no issue. Surely these faults cannot cause the car to stall and not start? Please advise
Thanks
Sam
Old 12-12-2009, 11:08 PM
Sketch o5's Avatar
Default Re: Accord 2001 wont start and stalls
from this link...
http://www.6thgenaccord.com/forums/s...t=p0700#post39
it says the codes youre getting are related to the auto trans.
just scroll down, and youll see that the p0700 code is highlighted red, and the rest of the codes youre getting are in that line as well. maybe it could be your trans solenoid, idk though.
pacdecimal
07-04-2014 05:34 AM
alexdbest
Honda CR-V & Element
12
12-23-2013 03:55 PM
honkylion
08-07-2013 07:28 AM
hondalion
06-25-2013 06:21 AM
sam786
01-01-2010 10:53 AM
Quick Reply: Accord 2001 wont start and stalls
