oil leak location
Old 06-22-2003, 06:38 PM
blah13's Avatar
Default oil leak location
Aight, I was changing my moms oil (93 accord lx, auto) and saw a lot of residue etc. So I cleaned it all up and found out where its leaking from. Its right above the oil filter, but also right above it is a hose that runs from one side of the head/block to the other so I cant see exactly where its coming from. It looks like a coolant hose but I'm a civic guy and mine dont have that hose so...and its definately not the valve cover leaking....
What is that hose? Coolant/oil?
And is the head gasket location right above the oil filter? I assume thats 1 similarity between F and D series...however there is no power loss, no collant missing, and no milky oil, which are all associated with the head gasket...
And on a random note when I added oil I looked in her filler hole and everything is a dark red, almost like AT fluid. My civic is dark brown and my ZC is silver(cleaned the head), is this normal? Many thanks!
Modified by blah13 at 3:51 AM 6/23/2003
Old 06-22-2003, 07:06 PM
Stripped Honda's Avatar
Default Re: oil leak location (blah13)
my guess is that it is the valve cover leaking not the head gasket try looking from the top with a flashlight
Old 06-22-2003, 07:11 PM
blah13's Avatar
Default Re: oil leak location (Stripped Honda)
Its definately not the valve cover...its completely clean, I can see the oil coming out from under the hose that runs right above the filter...thats why I need to know whether thats a coolant or oil line. Otherwise its got to be behind it. I've read on 96 accords the oil pressure sensor is right above the filter but didnt see such a thing on my moms.
Old 06-23-2003, 12:00 AM
iam7head's Avatar
oil pressure sensor have a little cap like rubber thing on it.
the oil cooler is leaking?? they have on on F series??
i think they have one on prelude h22a and Rsx-S engine.
Old 06-23-2003, 05:11 AM
jweller's Avatar
Default Re: oil leak location (iam7head)
It's hard for me to say 100% what the line is without a pic, but I'm 99.9% certain it's a coolant line.
F series dont have the little oil cooler box like the B series do.
Old 06-23-2003, 06:10 AM
StimpyBoy's Avatar
All of the hoses going into the manifold/head are coolant lines, I'm pretty sure there's no oil lines on a 93 Accord. So you're probably looking at a coolant leak. That's the area of the thermostat as well, so there's lots of coolant movement around there.
Old 06-23-2003, 08:35 AM
blah13's Avatar
Default Re: oil leak location (StimpyBoy)
Well if its a coolant line then its got to be the head gasket...I find it very odd though to get oil coming from the headgasket but no milky oil, and no coolant loss. I took the valve cover off so like I said before its defiantely not coming from there. I'd have to take off the intake mani to see where its exactly coming from. I first thought it was the oil filter bc it comes from right behind it and down around the fliter. Yay...thanks for the help though.
S.O.R.
02-08-2012 07:27 PM
dj00140
04-06-2010 09:41 AM
CivicSiDriver02
02-24-2006 08:39 PM
jason190
03-31-2005 08:12 AM
el3vate
03-26-2005 02:06 PM
Quick Reply: oil leak location
