94 rear disc to 90 accord? sedan
I have the whole rear sub-frame with trailing arms off a 94 accord. I was wondering if it would bolt up to my 90 accord? the 94 was a sedan i pulled it off of. and i have the e-brake cables with them. my 90 accord is also a 4 door. I was wondering is anyone has done this before and give me some input if it is a direct swap to my 90 accord from the 94 accord with e-brake cables.
thanks
thanks
Re: 94 rear disc to 90 accord? sedan
funny.. haha. i just swapped the 90 rear discs into a 94 lx that had drums. i am not 100% sure on the sub frame. but i do know that the hubs and control arms all fit.
hope this helps.
and yes we used the 90 ebrake cables on the 94 also.
hope this helps.
thanks for responding. I guess the whole suspension can work. but when I get the time to swap it i'll see if the sub frame can fit on the 90. only reason i ask is because i bought the e-brake cables new from Honda and it wasn't that cheap at all. so i want to be able to use them.
irishbobby23
01-23-2008 07:11 PM
