Loud Screeching Noise when Braking
Old 11-01-2007, 12:41 AM
Donboss's Avatar
Default Loud Screeching Noise when Braking
I have a 99 accord and whenever i brake theres a loud *** screeching noise and its getting outta control, i just recently put on new brake pads so i know it isn't the brakes...what els could it be, firestone told me it was the rotors and that they have heat spots....should i just get some new rotors? to stop the loud noise
Old 11-01-2007, 05:06 AM
YeuEmMaiMai's Avatar
Default Re: Loud Screeching Noise when Braking (Donboss)
time to change your brakes and most likely a rotor....that loud screeching is metal on metal contact
Old 11-01-2007, 07:45 AM
radiuslight's Avatar
Default Re: Loud Screeching Noise when Braking (YeuEmMaiMai)
When you change brakes The rotors have to be cut (dont buy new one unless you really need them ROTORS)
Old 11-01-2007, 10:36 AM
Honda-Master's Avatar
did you install honda pads ?? if not ,,non factory pads have a tendency to be extra noisy. also take a look at the rotors might need to be machined
Old 11-01-2007, 10:38 AM
aries331's Avatar
Default Re: Loud Screeching Noise when Braking (radiuslight)
You should always replace or resurface your rotors whenever you install new pads, no matter how good the pads are they will screetch like hell if this is not done.
Old 11-01-2007, 11:23 AM
Ronin1's Avatar
This is the sort of work that should be done either by a dealership or a shop that works on Hondas, not the Goodyear/Firestone/Brake Check stores that "work on all cars".
Frequently they do not have the proper equipment to surface the rotors correctly and use brake pads that are not the best for your car and more often than not simply do not have either a brake (anti-squeal) shim that goes between the brake pad the the piston in the caliper or a brake pad that has an anti-squeal design to it. The brake pad material may also simply not be right for your car.
I have seen cars come out of such shops that made such a noise when braking that the owner never even parked the car before returning to complain, which you should. If they do not resolve it, ask for a refund...and take the car some place else.
Old 11-01-2007, 12:45 PM
Donboss's Avatar
Default Re: Loud Screeching Noise when Braking (Ronin1)
oh yea well i put in new brake pads not too long ago but i was told that my rotors had heat spots...so should i just buy brand new pads again along with a set of front rotors? or should i save money and just get the front rotors
Old 11-01-2007, 12:53 PM
He knows where you live!
TheMuffinMan's Avatar
The pads you put on have probably worn unevenly.
I'd just replace rotors and pads
Old 11-01-2007, 04:17 PM
Donboss's Avatar
Default Re: (TheMuffinMan)
ok thanks guy im prolly gonna try and get new rotors and new pads as well
for my car model a 1999 honda accord 4dr 4cyl would i only need front brake pads and front rotors? or do i need all four
michelle902
Suspension & Brakes
01-23-2014 11:58 AM
nhldogg
08-13-2010 04:47 AM
icebluecivic21
04-29-2008 10:56 PM
Landshark68
04-20-2007 10:01 AM
endlessdv
05-17-2004 07:44 PM
Quick Reply: Loud Screeching Noise when Braking
