92 accord fuel pump control question, Honda Tech's please help
Old 08-24-2005, 08:45 PM
blkb18's Avatar
Default 92 accord fuel pump control question, Honda Tech's please help
the ecu supplies a ground to the main relay called "fuel pump control". The ecu intermittently does not supply this ground so my fuel pump doesent work sometimes. I've checked the harness, checked the main relay twice (before i found the ground problem). Before i try a ecu, is there any other part that can be bad that would cause the ecu not to give ground?
Old 08-25-2005, 05:48 AM
JimBlake's Avatar
Default Re: 92 accord fuel pump control question, Honda Tech's please help (blkb18)
Have you actually verified that the switched ground in the ECU is intermittent? I guess that would count as a fried ECU, since you don't routinely replace those components within the ECU. You can check for loose connections at the ECU plug of the wiring harness, or stuff like that?
I think it's more common for continuity thru the relay to be intermittent. (Cracked solder joints on that board...) Inspect those solder joints, sometimes they only go open when the main relay is mounted in place & it gets hot.
Old 08-25-2005, 06:08 AM
Duane_in_Japan's Avatar
Default Re: 92 accord fuel pump control question, Honda Tech's please help (JimBlake)
Create your own ground contact at the ECU pin terminal so as to not disturb the main relay itself, if the fuel pump never fails due to your ground then do a voltage drop check of the ECU's ground circuits to see if there is resistance causing these problems, Honda ECU's are pretty good but of course like anything, not bullet proof. I will do a quick search in my own large database and get back with any better info, no further answer, no better info.
Old 08-25-2005, 06:37 AM
deserthonda's Avatar
try a quick test to see if it is the relay or ecu...give manual ground at green/black wire ( fuel pump contorl ) going into the relay if u still got problems it is the relay if not it is the ecu..
if a faulty ecu thus relay wont have ground and wont energize u can try bypassing the relay by jumping wires at relay blk/yellow and yellow...the black yellow wire only has power in run or start mode so when u take the key off your pump wont be energized all the time
jruiz034
Engine Management and Tuning
02-04-2014 06:20 PM
JT2
Honda Civic (2001 - 2005)
06-23-2009 06:37 PM
krysted9354
20
04-08-2009 03:32 PM
lledcomp
04-05-2007 06:20 PM
Quick Reply: 92 accord fuel pump control question, Honda Tech's please help
