Locating/Identifying SCS service & MES connectors help needed. 98 accord
dAng!
I have a 98 accord lx that I am trying to reset the SRS light on. I searched and located instructions, but I do not know what the SCS service and MES connectors look like or exactly where they are. Could someone either post a diagram, tell me where to go look, or describe what they look like and where they're located?
Thanks in advance.
Thanks in advance.
Re: Locating/Identifying SCS service & MES connectors help needed. 98 accord (Russ713)
i believe the 6th gen mes connector is in the under dash fuse box..usually a yellow connector with 2 gray wires in it. Its connected to a dummy connector that has no prongs in the fuse box...
dAng!
Re: Locating/Identifying SCS service & MES connectors help needed. 98 accord (one clean ride)
thank you. I'll try to look for that plug. If anyone knows the other connector, please feel free to chime in and point me in the right direction if you don't mind. Thanks again.
look up, it's near the hood release handle, there two identical yellow connector without any connection, there's a closer one and the other one is deep in.
they look the same, same size, color, etc
you'll need to jump the deeper(the one harder to reach) on
dAng!
Okay, I crawled under the dash and located a narrow connector plugged into a dummy slot. The next yellow connector was larger and actually plugged into a true slot. Am I looking at the right ones on a 98 accord lx? I I noticed that there should be two of the same size plugged into a dummy slot, but i could not see another anywhere.
CrazyRexBoy
02-21-2007 05:28 PM
XViEtBoiX
08-27-2003 06:43 PM
masterk0ns
07-28-2003 09:17 PM
