Installing CD player into 92 Accord
Old 06-07-2003, 06:43 PM
VSMHatcH's Avatar
Default Installing CD player into 92 Accord
anyone got a link on how to remove all the panels(around the deck) and factory deck in a 92 accord
in order to install a deck?
Old 06-07-2003, 07:29 PM
ratherbewalking's Avatar
Default Re: Installing CD player into 92 Accord (VSMHatcH)
this should be in the audio/security forum... but ill thow some guidance your way.
its real simple, you gotta look behind the radio as in lay on the floor and get a flashlight. theres two (2) 8mm bolts. youll need a "skewdriver" or something that flexes to get to these. you can usally only get to these from the pass. side. it takes patients if you dont have the correct tools. after you get these 2 bolts out the radio should pull right out.
Old 06-07-2003, 08:09 PM
Starrman85's Avatar
Default Re: Installing CD player into 92 Accord (ratherbewalking)
you also need to take out the ash tray, which there are 3 screws holding that up. i have a link on how to do it, somewhere on my computer. let me see if i can dig it up somewhere.
Old 06-07-2003, 08:22 PM
Starrman85's Avatar
Default Re: Installing CD player into 92 Accord (STARRMAN85)
ok, heres the link. this is what i used when i installed my stereo.
http://www.installdr.com/Insta...3.pdf
good luck!
Old 06-08-2003, 11:04 PM
Peter Griffen
Guest
Posts: n/a
There is a screw in the back that holds the OEM unit.
Unscrew that and it all comes out.
If you are taking out panels you are doing it wrong.
Happs
Audio / Security / Video
07-08-2023 08:46 PM
Dfranke17
12-11-2010 09:56 AM
Sarge! Carry On!
10-28-2006 08:26 PM
92accrdLX
08-06-2004 02:03 PM
JDMCRX
03-02-2004 05:40 AM
Quick Reply: Installing CD player into 92 Accord
