Accord F22B1 with T2T4 or M2B4
Old 08-18-2020, 08:29 AM
Accord97F22B1's Avatar
Default Accord F22B1 with T2T4 or M2B4
Regards,
I have a 1997 Accord with a F22B1 sohc vtec engine, I want to change the box for one with a shorter ratio, such as the T2T4 or the M2B4 that comes in the Preludes.
Will I have a problem when changing? If compatible with the Cuirass? Or would I have to make an adaptation?
Old 08-18-2020, 10:59 AM
Premium Member
Aradin's Avatar
Default Re: Accord F22B1 with T2T4 or M2B4
No. Simple as remove and replace if your vehicle is already 5 speed.
Old 08-18-2020, 04:51 PM
GhostAccord's Avatar
Not sure if the VSS sensor connectors are the same or not???? That would be the only thing I can think of to watch out for. Other than that, they drop right in, use the same axles, mounts and all.
jaygood2go
07-01-2013 02:36 PM
Rishiras
03-02-2006 02:50 PM
d15civ
11-19-2004 06:11 PM
hybridracer504
03-13-2004 06:57 PM
Quick Reply: Accord F22B1 with T2T4 or M2B4
